ECU change
2.7 V6 30v biturbo - 380 bhp
ANBR
ECU change
Post by ANBR » Wed Aug 18, 2004 9:43 pm
Hi
Can someone tell me what will hapen if i change the ECU of my car with ASJ Engine with my friends ECU that is Build for AZR motor but has upgrade to 430Hp . Can we just do this ?????
kcsun
Post by kcsun » Wed Aug 18, 2004 10:37 pm
No
You have to contact Audi to get programming codes to swap the ECU's
kc
ANBR
Post by ANBR » Wed Aug 18, 2004 11:16 pm
Thanks so far
I Know that when you change the ECU that you have to typ in the old ECU code and you do need this VAG 15.. someting for it . But other then that is there anything else i have to watch ?? ASJ or AZR can the ECU just be switched ??? The tuners better to say MTM and sportec and so on do they have 2 diffrent program for the RS4 ??? one for AZR motor and one for ASJ ?????
PhilT
RS246.com
Post by PhilT » Thu Aug 19, 2004 7:44 am
I wouldn't recommend it. WHy not contact the tuner who did the map on the chipped ECU?
excursion
Post by excursion » Thu Aug 19, 2004 8:26 am
Are you are sure the 2 ECU's are interchangeable and compatible with each engine code....? Usually a change in engine code signifys something significant eg an additional air injection system
Here is the procedure anyway http://www.ross-tech.com/vag-com/cars/I ... pping.html
sitas3
Post by sitas3 » Thu Aug 19, 2004 8:45 am
there are differences in the emission control and monitoring systems between the two ECU/engine codes. Although Audi say that technically the physical engines are the same.
I'd say really that it may not be practical to be using an ecu designed for a different RS4 engine code, however I'm aware of one or more people doing just that!.
Golich
Post by Golich » Thu Aug 19, 2004 12:35 pm
I'd contact the tuner. From memory the difference was in the Euro emissions bla bla bla. I'm sure the details are in the RS4 tech's self study programe. Which you can download from this site.
zorroRs4
Post by zorroRs4 » Thu Aug 19, 2004 1:41 pm
speaking of witch,how much for a new ECU?
ANBR
Post by ANBR » Sat Aug 21, 2004 10:09 am
Thanks for all the good answers. I still dont know if ishould try it but i will let you all know
cheers
Nige_RS4
Post by Nige_RS4 » Sat Aug 21, 2004 2:04 pm
I would only recommend changing ECU's if you have the same ECU part # - even then you will need VAG-COM or similar to reprogramme it (you need to make a note of the old ECU code before you remove it too!).
Nige.
Users browsing this forum: No registered users and 92 guests
