Is this normal
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Druggie
Is this normal
Post by Druggie » Mon Aug 02, 2004 5:34 am
If you have just moved off from a standstill and then floored the accelerator to the floor to avoid being run up the bum by some idiot, what is supposed to happen?
What happened to me was that the car seemed to bog down and even though it was accelerating , it wasnt accelerating with its usual ferocity. It continued to do it in the next 2 gears while i had the acclerator floored.
After the emergency i eased the pedal to the floor and the car accelereted as normal.
Now is this some ecu or throttle by wire idiosyncrasy that i must remember not to do when needing full engine power and acceleration.
Or ???
Tony
S4- Possession without prescription is illegal
2000 S4 Silver, currently stock
Dippy
Post by Dippy » Mon Aug 02, 2004 12:25 pm
Unfortunately yes it is normal.
As you note, your car is DBW so the ECU can intercept and modify the action of your right foot. There definitely are circumstances where the ECU will make adjustments, but I have yet to discover the details. Certainly the car will respond better to progressive use of the gas pedal rather than pushing it to the floor.
Also, although I have no confirmation, I believe that the S4 can suffer from hesitation due to the DV system. This has happened to me. I have alleviated it somewhat through use of stronger springs, but it has not disappeared altogether.
Anyway, next time it happens to you, immediately lift off and reapply the pressure, but more gently. You should find that it will recover.
2001 Silver S4 Avant
Druggie
Post by Druggie » Mon Aug 02, 2004 2:06 pm
I guess the foot to the floor rex days are over.....
Tony
vw_nutta
Post by vw_nutta » Mon Aug 02, 2004 7:07 pm
yep, I've found this. Pain in the bum but if you get the right foot right then it all becomes a blurr!
[img]modules/pnCPG/Coppermine/albums/userpics/11703/rs246_thmb_S4front.jpg[/img]
DavidR
Post by DavidR » Mon Aug 02, 2004 8:48 pm
Hmm, not sure I follow the logic in this, or have noticed the WOT causing such problems as described.
My explaination for a similar thing is that if you are really brutal in 1st / 2nd and the road condition is not fantastic, then ESP intervenes, limits the power and flashes the warning light at you in an accusing manner.
Druggie
Post by Druggie » Tue Aug 03, 2004 1:17 pm
Nope it wasnt the esp intervening as i experienced that sensation today. The car just felt like it was chocking and not getting enough air to accelerate cleanly.
Tony
Dippy
Post by Dippy » Wed Aug 04, 2004 1:06 pm
David,
Maybe your car's different, but the issue is well known about on AudiWorld too.
Golich
Post by Golich » Thu Aug 05, 2004 1:00 pm
Very interesting, I think I remember reading about this some time back. Personally I've not experienced this prob with either my previous S4 or my current RS4. With the exception of the traction control's part.
I'd be amazed if Audi/Bosch had designed such a crap feedback system that the ECU takes more than a couple of nano seconds to work out the postion of the throttle and respond accordingly. Or worse still if the motor that opens throtal body flap was so slow to respond!!
I wonder if radio interference is possible - mobile phones?
Nige_RS4
Post by Nige_RS4 » Thu Aug 05, 2004 2:14 pm
I would say that this was more ESP-related than the any 3/4 throttle 'feature' discussed on AWhere ... http://forums.audiworld.com/s4/msgs/993185.phtml
I'm not saying do this mod, but from my experience there seems to be some truth in not stamping on the gas pedal, especially on the motorway in a high gear.
Nige.
