MPG???????????
2.2 I5 20v turbo - 315 bhp
Rob20vurq
MPG???????????
Post by Rob20vurq » Fri Jul 02, 2004 9:19 pm
My car must be poorly, it gives an initial big blast of power when the turbo finaly kicks in then seems to hesitate and then the power fluktuates,coming and going. It still pulls to the limiter but not like it should.
I've been right through the pipework for a leak but all seems fine.The biggest give away is the <beep> MPG, 20 on a run 16.5 round town, black soot allover the tail gate,bumper!!
Any Ideas??
It has not been chipped.......but it soon will be if no one can sort it.
robo
Post by robo » Fri Jul 02, 2004 10:20 pm
First job is fuel and air filter, My one droped from 15.5 to 13.5lL per 100km
just cant get enough of it
DAVIDP20V
Post by DAVIDP20V » Fri Jul 02, 2004 11:03 pm
agree with robo, change fuel filter,air filter and do plugs aswell
do the ipa, air mass meter cleaning trick aswell. always makes a difference.
blacksoot @ the back (i thnik) means unburnt fuel so all of the above can only make it run better .
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
Rob20vurq
Post by Rob20vurq » Sun Jul 04, 2004 10:17 pm
I've done the air filter, plugs look fine not worn, its only done 32.000 miles, fuel filters are usally fit for life on Audis?, I will have fault codes read tomorrow. been to London and back this weekend bloody expensive,supped a tank and a half!!!!!
Thanks for the replies!
alastairg
Post by alastairg » Mon Jul 05, 2004 8:56 am
Agree with above. Fuel filter should be changed not fit for life. Remeber unburnt fuel kills cats
quattroturbo
Post by quattroturbo » Tue Jul 06, 2004 12:15 am
Have your O2 sensor checked or replaced. If this is faulty it will automatically run rich. Chipping it will not fix the problem, you have to make sure it is running 100% before you do any performance tuning.
Rob20vurq
Post by Rob20vurq » Wed Jul 07, 2004 9:55 pm
I think I've fixed it! Had the fault codes read and it came up with lamda probe, checked connection and the bracket that holds the plug was stopping the plug connecting fully,pushed the down plug a bit further and then the connector could click home.
seems ok, off to Bedford in the morning so I'll give the mpg a test! :D
Rob20vurq
Post by Rob20vurq » Fri Jul 09, 2004 10:07 pm
:evil: Well its not fixed!!!!!! I've tried a new lamda, no better!!! Its running super rich!! give it a rev at standstill and it chuffs a cloud of black unburnt fuel out!
I have been told to try the temp sender to the ecu,if it thinks its cold it will over fuel? If not it might be the air flow meter(air mass)?
Any thoughts on these ideas? :cry:
Rob20vurq
Post by Rob20vurq » Sat Jul 10, 2004 9:16 pm
vAG comed it today and the water temp sender is telling the ecu that engine is at -49!!!!!!!!!!!!!! when hot.
Orderd new sender,hopefully this sorts it!!!!!!!
:wink:
Rob20vurq
Post by Rob20vurq » Thu Jul 22, 2004 8:18 pm
No its still <beep>!!!!!!!!!!! still showing -49 with new temp sensor (the white one one the back of the head) and new temp sensor on the water rail (three pin brown) checked wiring to ecu,did continuaty test all ok.
Its looking like an ecu fault!!!!!!!!!!!!!!
Anyone live Yorkshire way? it would be nice to try another ecu to confirm the problem!!
alastairg
Post by alastairg » Mon Jul 26, 2004 8:50 am
Give the S2 forum boys a try as there is a lot of knowledge there.
ralphb
Post by ralphb » Thu Sep 16, 2004 9:29 pm
Rob
Did this come right? Sounds EXACTLY like what I recently went through with smoking on acceleration and soot on the rear bumper (I've just posted my story on the "to MOD or not to MOD" thread. As I said, I don't know whether it was the lambda sensor of the modified chip, and it might have been both...! Running beautifully now, except without the kick.
Users browsing this forum: No registered users and 6 guests
