S4 Turbo Poll
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Have you had turbo problems in your S4?
Turbos Replaced below 60k!
4
15%
Over 60k and Still Blowing!
14
54%
Over 100k and Still Blowing!
4
15%
Dont know the cars past!
1
4%
Turbo Upgrade Carried Out in your quest for power!
0
No votes
Turbo Upgrade Carried Out due to failure of KKK03!
3
12%
Total votes: 26
gavsteryoung
S4 Turbo Poll
Post by gavsteryoung » Wed Jun 23, 2004 3:07 pm
There is always talk of Turbo problems with the S4, to be honest im not suprised, the way things are packed in, the heat build up must be huge!
Any way lets run a little poll, select which best applys to your S4 and its past!
SimonS4MTM
Post by SimonS4MTM » Wed Jun 23, 2004 4:12 pm
I carried out a similar poll a while ago, the results are still here somewhere.
I have voted for my old car 85k original turbo's. Currrent car has 47k original turbo's not could not vote for that one.
gavsteryoung
Post by gavsteryoung » Tue Jun 29, 2004 4:23 pm
Sorry, I should have seached through the forum. Looks like I better put some cash away in expectation.
im at 70k and orginal turbos, car still seems to pull well, and they make the usual siren noise like a police car is chasing me!!!
Verruckt
Post by Verruckt » Sat Jul 03, 2004 11:38 pm
I blew the K03's at 50k. Then in went the K16/K04 hybrids. :twisted:
Dippy
Post by Dippy » Mon Jul 05, 2004 12:20 pm
Yes, if your turbos are making a siren sound then they are definitely on the way out.
2001 Silver S4 Avant
sitas3
Post by sitas3 » Mon Jul 05, 2004 12:26 pm
my original turbos made a siren noise and when I reported this to the dealer, they replaced them both under warranty.
gavsteryoung
Post by gavsteryoung » Mon Jul 05, 2004 1:04 pm
I guess that was somthing I didnt want to hear!
They still pull like crazy, and have been doing since I got the car...... i've only done 5000 miles but seems fine,
its louder when its cold, then quiets down a bit..... I thought I siren was ok, but a dentist drill was not!!
Dippy
Post by Dippy » Mon Jul 05, 2004 3:41 pm
The term "dentist drill" is not the best analogy but it's then best I can think of. Forget the drill itself, just think about a well-lubricated fan spinning at high revs. There's no metallic part to the sound, which is why sometimes it is described as a "whistle".
AFAIK the siren comes in when the turbine is not spinning steadily resulting in resonance which produces the sound. This is also why it is worse when cold, because the oil has not reached the correct viscosity yet. This is also why a healthy turbo can make a feint siren sound when it is cold, but not when it is hot.
If you do not have any warranty, consider doing something about it soon. The risk is that one of the turbines could rub against the turbo housing and a piece break off. This could then enter the intake and risk engine internal damage. Then it's not just the cost of the turbos you'd have to worry about...
gavsteryoung
Post by gavsteryoung » Mon Jul 05, 2004 4:09 pm
Ok, I have emailed Kim Collins (as he is nearer than AMD) and am going to get them to do my 70k service. And give me a health check, and see if he thinks they are particulary loud....
I guess coming to think about it I guess they do whistle more than a siren.
But I can still hear it when its hot, but not on the motorway when accelarating only pulling out of junctions of when going say under 40. I guess that may give you a indication of how loud they are. After that road noise hides the turbo sound.
Maybe I am worrying after nothing!
I certainly cant really afford the 4or5k it may cost to replace them!
Dippy
Post by Dippy » Mon Jul 05, 2004 4:17 pm
Don't forget that not only do the turbos rarely produce a lot of boost on the motorway, but at high speed the general noise of engine and tyres would drown out turbo noise anyway.
However Kim will be able to give the best judgement.
excursion
Post by excursion » Wed Jul 07, 2004 12:10 pm
Verrückt wrote:I blew the K03's at 50k. Then in went the K16/K04 hybrids. :twisted:
Can you give me any more information on this, mate?
sitas3
Post by sitas3 » Wed Jul 07, 2004 12:25 pm
Dippy wrote: However Kim will be able to give the best judgement.
yes it was Kim that diagnosed my 'Dodgy' turbos which then resulted in the dealer replacing them under warranty.
gavsteryoung
Post by gavsteryoung » Wed Jul 07, 2004 1:13 pm
I have no warrenty, so im hoping there going to be fine..... 3 or 4k aint no joke!!
gavsteryoung
Post by gavsteryoung » Mon Jul 19, 2004 1:17 pm
Well, my car had a full service and check over at QST on Friday!
Turbo's are fine, and pressure test was also fine! Thank goodness for that!
Noticed Kim and staff were wearing RS246 tops!
Was also Noggie Blue Avant up on the ramp on friday! Anyone's Here! + Red RS4 out front!
KayGee
Post by KayGee » Fri Jul 30, 2004 12:36 am
Mine makes a whistle at low RPM then trails away to nothing.......apparently it's the turbos but having owned three turbo cars I'm not convinced. When the turbos went before it got louder as the turbos spooled up. I think it's a vacuum leak but it passed a QST pressure test. Anyway 47K and still blowing.
