PEAK BOOST ?
2.2 I5 20v turbo - 315 bhp
DAVIDP20V
PEAK BOOST ?
Post by DAVIDP20V » Fri Feb 20, 2004 9:59 am
hello peeps
what does youer rs2 boost at ?
peak and what does it settle to ?
any replies would be helpful [img]images/graemlins/thumbs.gif[/img]
standard should be 1.4 bar (20-21 psi) is this constant or peak
i think my car feels slower or i maybe getting used to the power ?? [img]images/graemlins/spineyes.gif[/img] ??
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
Jani
Re: PEAK BOOST ?
Post by Jani » Fri Feb 20, 2004 12:25 pm
Standard is peak 1.4, about 1.0-1.1 at 7000 rpm. Stock turbo can't keep the boost up at high revs -and your engine internals wouldn't like it if it did...
Mine peaks 1.9 at 3500-4500, settling to 1.3 by 7000 rpm. Had it for 4+ years now, doesn't yet feel slow [img]images/graemlins/grin.gif[/img]
Kramrs2
Re: PEAK BOOST ?
Post by Kramrs2 » Fri Feb 20, 2004 3:24 pm
My car had peak at 1,4bar and hold 0,9-0,95bar at 7000rpm in standard trim.
The biggest problem to engine internals are peak pressure (@ peak torque) and rev limit. So, if you stay with your rev limiter you could run your peak boost until there without problem, in theory (and turbo allowing).
Jani, in your car with close to 400hp and 60Kgfm, it must be more difficult to be used to the power [img]images/graemlins/tung2.gif[/img]
DAVIDP20V
Re: PEAK BOOST ?
Post by DAVIDP20V » Fri Feb 20, 2004 4:45 pm
So if my car is boosting at around 21-22 psi peak then coming down to around 16-18 psi @ higher revs this is ok and i am getting used to the power [img]images/graemlins/thumbs.gif[/img]
i am sure it feels slower though [img]images/graemlins/033102bad_1_prv.gif[/img]
Davidp20v
jubjub
Re: PEAK BOOST ?
Post by jubjub » Fri Feb 20, 2004 10:40 pm
Sorry to divert a little but,does it matter what boost gauge you have,as in is it better to read in psi or bar?
Doug_RS2
Re: PEAK BOOST ?
Post by Doug_RS2 » Fri Feb 20, 2004 10:49 pm
what do you understand better jubjub?
I understand 30psi(peak) and 25psi (7600 redline) - more than 2.05 Bar and 1.7Bar so I have a gauge with psi. I'll need a new one though as 30psi is the limit and I will be going over that soon.
DAVIDP20V
Re: PEAK BOOST ?
Post by DAVIDP20V » Sat Feb 21, 2004 11:45 am
More than 30 psi ! [img]images/graemlins/clap.gif[/img] [img]images/graemlins/bowdown.gif[/img]
I prefer psi but no odds really 1 bar = 14.7 psi
Davidp20v
Users browsing this forum: Google Adsense [Bot] and 37 guests
