hello peeps
what does youer rs2 boost at ?
peak and what does it settle to ?
any replies would be helpful [img]images/graemlins/thumbs.gif[/img]
standard should be 1.4 bar (20-21 psi) is this constant or peak
i think my car feels slower or i maybe getting used to the power ?? [img]images/graemlins/spineyes.gif[/img] ??
PEAK BOOST ?
PEAK BOOST ?
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
Re: PEAK BOOST ?
Standard is peak 1.4, about 1.0-1.1 at 7000 rpm. Stock turbo can't keep the boost up at high revs -and your engine internals wouldn't like it if it did...
Mine peaks 1.9 at 3500-4500, settling to 1.3 by 7000 rpm. Had it for 4+ years now, doesn't yet feel slow [img]images/graemlins/grin.gif[/img]
Re: PEAK BOOST ?
My car had peak at 1,4bar and hold 0,9-0,95bar at 7000rpm in standard trim.
The biggest problem to engine internals are peak pressure (@ peak torque) and rev limit. So, if you stay with your rev limiter you could run your peak boost until there without problem, in theory (and turbo allowing).
Jani, in your car with close to 400hp and 60Kgfm, it must be more difficult to be used to the power [img]images/graemlins/tung2.gif[/img]
Re: PEAK BOOST ?
So if my car is boosting at around 21-22 psi peak then coming down to around 16-18 psi @ higher revs this is ok and i am getting used to the power [img]images/graemlins/thumbs.gif[/img]
i am sure it feels slower though [img]images/graemlins/033102bad_1_prv.gif[/img]
Davidp20v
Re: PEAK BOOST ?
Sorry to divert a little but,does it matter what boost gauge you have,as in is it better to read in psi or bar?
Re: PEAK BOOST ?
what do you understand better jubjub?
I understand 30psi(peak) and 25psi (7600 redline) - more than 2.05 Bar and 1.7Bar so I have a gauge with psi. I'll need a new one though as 30psi is the limit and I will be going over that soon.
Re: PEAK BOOST ?
More than 30 psi ! [img]images/graemlins/clap.gif[/img] [img]images/graemlins/bowdown.gif[/img]
I prefer psi but no odds really 1 bar = 14.7 psi
Davidp20v
