ECS RACE N75 Valve
2.7 V6 30v biturbo - 380 bhp
zeke
ECS RACE N75 Valve
Post by zeke » Mon Feb 10, 2003 7:08 pm
Have anybody install this type of valve on the RS4?
This is the link http://www.ecstuning.com/stage/n75-info.html [img]images/graemlins/audiS4black.gif[/img]
RS4 B5 2002
RS4 B7 2008
RS6 C7 2018
Andiroo
Re: ECS RACE N75 Valve
Post by Andiroo » Mon Feb 10, 2003 11:04 pm
Not sure if anyone has tried this before on an RS4, although is seems to get some good reviews in the States - increasing boost up to 0.2bar on standard or chipped [img]images/graemlins/shocked.gif[/img]
Not sure what benefits we will gain on modified RS4's as the ECU control over the standard valve is different regarding boost levels anyhow. Still worth checking out though [img]images/graemlins/1syellow1.gif[/img]
Andiroo
WIP :to be advised.....
Greg_S
Post by Greg_S » Mon Feb 10, 2003 11:08 pm
will this not affect the way the ECU works out fuelling and safegauarding of the engine because it is effectively tricking the ECU into overboosting?
Bullshit baffles brains
Andiroo
Post by Andiroo » Mon Feb 10, 2003 11:16 pm
I think the ECU may compensate for the fuelling to some extent, especially as the increased boost will attract more air - not really sure mate, but it doesn't sound particularly safe does it [img]images/graemlins/wink.gif[/img]
Be interesting to know if anyone over here has one fitted.
Andiroo
piggie
Post by piggie » Tue Feb 11, 2003 1:30 am
fwiw, that ecs valve doesn't work on the S4 here in the states. the boost spikes to above 1.5 bar, then the ecu shuts the car down a bit by pulling the throttle shut. I guess some TT guys had good luck with it. You might want to just consider leaving the N75 plugged in and run a manual boost controller [img]images/graemlins/grin.gif[/img] Just as long as you don't cross the max pressure that the sensor can read(1.5Bar), you'll be ok. But the ECU can't throw your car into limp now, because it has no control over the wastegates any more. So you lose 1 safegaurd by using an MBC.
01 S4
92 G60 Corrado
Greg_S
Post by Greg_S » Thu Feb 13, 2003 7:35 pm
If you have to goto those lengths to use the valve it would more than likely be cheaper, safer and give better results by just having the car proffesionally chipped! [img]images/graemlins/shocked.gif[/img]
Andiroo
Post by Andiroo » Thu Feb 13, 2003 8:11 pm
Totally agree Greg [img]images/graemlins/smile.gif[/img]
Andiroo
zeke
Post by zeke » Thu Feb 13, 2003 11:36 pm
Maybe we can put the valve N75 and added a blow off valve just in case there is too much boost.
Regards
RS4 B5 2002
RS4 B7 2008
RS6 C7 2018
Greg_S
Post by Greg_S » Fri Feb 14, 2003 10:45 am
hmmm, but the turbo systems on these cars work on a closed loop anyway so all air into the engine in metered so that may also affect it too.
timucin
Post by timucin » Wed Oct 08, 2003 9:39 pm
[img]images/graemlins/grin.gif[/img] [img]images/graemlins/grin.gif[/img]
sorry friends but this comes standart on rs2
Quattro
bem_ho
Post by bem_ho » Thu Oct 09, 2003 3:53 am
I dealer in HKG said this valve is standard in RS4!!
cosworth27T
Post by cosworth27T » Thu Oct 09, 2003 9:50 pm
don't do it unless you are stock. S4s in the US has reported positve results in stock format, but negative in chipped formats.
Nige_RS4
Post by Nige_RS4 » Fri Oct 10, 2003 9:37 am
I think the general concensus for 2.7 S4's is that unless your standard, don't do it.
BTW, it is a std Audi part and VAG-parts can get hold of it (circa. £30'ish) - see this thread for more info.
Nige.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
zeke
Post by zeke » Tue Jun 21, 2005 1:36 am
Its been almost two years since I asked if anybody has tried this N75 Valve.
So anybody?
robobeastt
Post by robobeastt » Wed Nov 23, 2005 10:22 pm
Like they have said before ... the ECS valve is good when you have a stock mapping ... when chipped it can make your boost to spike and even cause limp mode... you don´t really want to use it on your MTM´ed RS4 :D :D :D ..... I know this because I have tried all kinds of N75s in my 1.8T ;) ... also the ECS N75 is an original part from Audi used in Rs2s ... they only erase the Audi codes from it and sell them like gold :?
By the way .... there is a way that close looped turboed systems can run Blow Off valves ;) ...... those are the hybrid BOVs ... I have run a Go Fast Bits for several months now on my 1.8T and have had no problems at all ..... http://www.gofastbits.com/index.php?par ... stealth_fx these hybrids vent out to the exterior and also to the intake system so that your ECUs don´t pull ut a code ;) .... there is even a sepcial kit made for al 2.7 Biturbos made by Aussie Turbosmart ... look here: http://www.turbosmart.com.au/ .... go to products, then to Compact Series and then roll down to the bottom of the page ;)
Regards !
Robo :)
Users browsing this forum: No registered users and 90 guests
