S3 OEM Brake Pads
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
Riz_RS4
S3 OEM Brake Pads
Post by Riz_RS4 » Mon Nov 03, 2003 11:05 pm
Is there a visual way of checking how much grip i have left on my pads..... the block itself has about 1.5cm thinkness.... does it wear all the way down or am i near to replacement time?
Riz [img]images/graemlins/29428-red4.gif[/img]
Image I`m just a hardcore petrol head :)
Hopsta
Re: S3 OEM Brake Pads
Post by Hopsta » Tue Nov 04, 2003 12:01 am
Theres 2 wires that are embedded into the pad, once this has been worn through you'll get an error come up on the DIS. Then its pad change time.
Always check your nuts before you have a play ! [img]images/graemlins/crazy.gif[/img]
Riz_RS4
Post by Riz_RS4 » Tue Nov 04, 2003 7:11 pm
Any idea what thickness these sensors are embedded into the pads? just trying to work out how many miles ive got left on my pads?
Riz [img]images/graemlins/beerchug.gif[/img]
Mo_S3
Post by Mo_S3 » Wed Nov 05, 2003 1:42 am
When ulook at the pad u can see the bit that does the braking and the and the metal that it is bonded to which is obviously a bit bigger. If ur pad is getting pretty near to the metal plate then expect ur brake warning lite to come on at anytime. Even with the brake light on u still have some life left in the pads so its not 'oh [censored] ive got no brakes' time just yet.
Do u follow that Riz ?
Riz_RS4
Post by Riz_RS4 » Wed Nov 05, 2003 9:50 am
Yup got it ... yippe looks like ive got around 1.2-1.5cm of pads left still.... quality
Riz [img]images/graemlins/s3addict.gif[/img]
Hopsta
Post by Hopsta » Thu Nov 13, 2003 8:43 am
You prepping up for the 2nd then Riz, your going to need more than that to get past Fatcat [img]images/graemlins/tongue.gif[/img]
Riz_RS4
Post by Riz_RS4 » Thu Nov 13, 2003 7:36 pm
Just making sure ive got enough pads left and to work out when i will need to have them changed [img]images/graemlins/wink.gif[/img]
p.s. there is no 2nd place.....
wazza
Post by wazza » Fri Nov 14, 2003 12:14 am
but there is a last place..... [img]images/graemlins/<beep>_you.gif[/img]
Paul
