Is there a visual way of checking how much grip i have left on my pads..... the block itself has about 1.5cm thinkness.... does it wear all the way down or am i near to replacement time?
Riz [img]images/graemlins/29428-red4.gif[/img]
S3 OEM Brake Pads
S3 OEM Brake Pads
I`m just a hardcore petrol head Re: S3 OEM Brake Pads
Theres 2 wires that are embedded into the pad, once this has been worn through you'll get an error come up on the DIS. Then its pad change time.
Always check your nuts before you have a play ! [img]images/graemlins/crazy.gif[/img]
Any idea what thickness these sensors are embedded into the pads? just trying to work out how many miles ive got left on my pads?
Riz [img]images/graemlins/beerchug.gif[/img]
When ulook at the pad u can see the bit that does the braking and the and the metal that it is bonded to which is obviously a bit bigger. If ur pad is getting pretty near to the metal plate then expect ur brake warning lite to come on at anytime. Even with the brake light on u still have some life left in the pads so its not 'oh [censored] ive got no brakes' time just yet.
Do u follow that Riz ?
My DVD System
Yup got it ... yippe looks like ive got around 1.2-1.5cm of pads left still.... quality
Riz [img]images/graemlins/s3addict.gif[/img]
You prepping up for the 2nd then Riz, your going to need more than that to get past Fatcat [img]images/graemlins/tongue.gif[/img]
Just making sure ive got enough pads left and to work out when i will need to have them changed [img]images/graemlins/wink.gif[/img]
p.s. there is no 2nd place.....
I`m just a hardcore petrol head - wazza
- Top Gear
but there is a last place..... [img]images/graemlins/<beep>_you.gif[/img]p.s. there is no 2nd place.....
Paul
