Gearbox/clutch
2.2 I5 20v turbo - 315 bhp
PHIL_SELF_2
Gearbox/clutch
Post by PHIL_SELF_2 » Fri Oct 10, 2003 3:40 pm
Do all RS2 drivers have to push the clutch pedal through the bulkhead to get into gear? In particular reverse is very difficult & first is almost as bad, after that it's a bit easier. It seems to have been worse in the hot weather & as I've only owned the car since July hot weather is what we've had most of. This makes gearchanging a chore & progress is best described as stately, not brisk. I've checked the clutch pedal travel - it bites about 25 mm off the bulkhead & it's not slipping as I've done a stall test using the footbrake, not the handbrake. I think it may be clutch drag. One suggestion is to replace the hydraulic fluid totally & make sure that there is no air in the system, but I haven't tried this yet. Are there any other adjustments please?
Regards
Phil
P R SELF
scillyisles
Re: Gearbox/clutch
Post by scillyisles » Fri Oct 10, 2003 4:14 pm
Do all RS2 drivers have to push the clutch pedal through the bulkhead to get into gear? No the clutch should be fairly easy and you should'nt have to push it through the bulkhead.
In particular reverse is very difficult & first is almost as bad, after that it's a bit easier. No the only change that sometimes causes problems on the RS2 gearbox is the first to second gear. Weak syncho on 2nd I believe It seems to have been worse in the hot weather & as I've only owned the car since July hot weather is what we've had most of. This makes gearchanging a chore & progress is best described as stately, not brisk. I've checked the clutch pedal travel - it bites about 25 mm off
This sounds way to close to the bulkhead - mine bites at a much bigger distance away from the bulkhead probably just under half the way out from the bulkhead the bulkhead & it's not slipping as I've done a stall test using the footbrake, not the handbrake. I think it may be clutch drag. One suggestion is to replace the hydraulic fluid totally & make sure that there is no air in the system, but I haven't tried this yet. Are there any other adjustments please?
Regards
Phil
Audi RS2 - the original
ABY
Re: Gearbox/clutch
Post by ABY » Fri Oct 10, 2003 7:25 pm
My s2 had the exact same problem as you describe.
The rod on the clutch master cylinder bent.
The clutch got harder and harder then the rod broke.
T [img]images/graemlins/kissmyrings.gif[/img]
JAMES
Re: Gearbox/clutch
Post by JAMES » Sun Oct 26, 2003 11:36 pm
phil this should be ok as i replaced the master cylinder and in doing so replaced fluid,but it is easy to check by removing the undershield by the pedals.
previous: RS2, RS4 2.7, RS4 4.2.
Current: S8 PLUS
DaveS
Re: Gearbox/clutch
Post by DaveS » Mon Oct 27, 2003 11:42 pm
Mine is only ever hard to get in to (1st) gear when its really hot - e.g. in stop start motorway traffic. Then I have to resort to putting it in 2nd then first to get away.
In normal motoring its fine, though you could never call it a brisk change.
Ragusa Green RS2
timucin
Re: Gearbox/clutch
Post by timucin » Tue Nov 04, 2003 12:41 am
are stock clutches good for engine-tuning?
or do i have to upgrade them when running like 400+hps'?
Quattro
Jani
Re: Gearbox/clutch
Post by Jani » Tue Nov 04, 2003 8:18 am
Stock is good, if not worn. Will take more than 600 Nm.
timucin
Re: Gearbox/clutch
Post by timucin » Tue Nov 04, 2003 11:24 am
more than 600nm!
[img]images/graemlins/thumbs.gif[/img]
Quattro
Users browsing this forum: No registered users and 44 guests
