No warm air only cold
Tadass910
Post by Tadass910 » Fri Nov 03, 2023 10:57 pm
Hello, recently my car started blowing only cold air through the air vents but not hot air, even when I set 28 plus it’s not blowing hot air, what could be an issue?
morski
Re: No warm air only cold
Post by morski » Sat Nov 04, 2023 1:29 pm
Check if you have hot water coming into the cabin area by feeling the pipes in the plenum chamber. There is a valve there which could be the issue
RS6 Performance Ascari blue, Carbon Ceramics, Akrapovic, H&R Anti Roll bars
Tadass910
Post by Tadass910 » Sat Nov 04, 2023 8:33 pm
Thanks Morski, where those pipes are? More over I scanned today with carista and got those codes: I think I need a visit to my dealer. Also my front window is foggy when driving in a rainy conditions, only helps when using ac with to defrost window but it’s very cold inside a car
morski
Post by morski » Wed Nov 08, 2023 11:59 pm
Take off the panel under the windscreen. You will see the 2 pipes entering the cabin area from the engine bay. there is a pump there as well so check the temp on the pipe pre and post pump.
Until you get the air temp sorted coming into the cabin you will have condensation issues in the cabin
Tadass910
Post by Tadass910 » Sat Nov 11, 2023 8:20 am
Thanks m8, fixed appointment at Audi
Tadass910
Post by Tadass910 » Fri Nov 17, 2023 5:55 pm
It’s strange but it started warming up, not sure what happened….but it fixed itself
Users browsing this forum: No registered users and 126 guests
