Hello, recently my car started blowing only cold air through the air vents but not hot air, even when I set 28 plus it’s not blowing hot air, what could be an issue?
No warm air only cold
Re: No warm air only cold
Check if you have hot water coming into the cabin area by feeling the pipes in the plenum chamber. There is a valve there which could be the issue
Thanks Morski, where those pipes are? More over I scanned today with carista and got those codes: I think I need a visit to my dealer. Also my front window is foggy when driving in a rainy conditions, only helps when using ac with to defrost window but it’s very cold inside a car
Take off the panel under the windscreen. You will see the 2 pipes entering the cabin area from the engine bay. there is a pump there as well so check the temp on the pipe pre and post pump.
Until you get the air temp sorted coming into the cabin you will have condensation issues in the cabin
Thanks m8, fixed appointment at Audimorski wrote: ↑Wed Nov 08, 2023 11:59 pmTake off the panel under the windscreen. You will see the 2 pipes entering the cabin area from the engine bay. there is a pump there as well so check the temp on the pipe pre and post pump.
It’s strange but it started warming up, not sure what happened….but it fixed itselfmorski wrote: ↑Wed Nov 08, 2023 11:59 pmTake off the panel under the windscreen. You will see the 2 pipes entering the cabin area from the engine bay. there is a pump there as well so check the temp on the pipe pre and post pump.
Users browsing this forum: No registered users and 72 guests
