Suspension Faults (VCDS)
HDPete
Post by HDPete » Tue Jan 17, 2023 2:07 pm
Hi,
Over the last few days, I have had a series of warnings which started with a yellow Air Suspension Fault and various related things, like the ACC and Brake Guard disabled. I had just completed a rather wet long distance drive and put it down to water in the electrics somewhere.
The next day, the red Air Suspension Warning came on and I could hear the car rubbing its wheels in the arches. I have a CETE module and have managed to lift the car up again, but the amber fault keeps coming back. The CETE module is in bypass mode, so I don't believe that it is causing the issue.
A VCDS scan reveals the following, which suggests a mechanical sensor fault. It is likely to be water in the plug (and how easy is it to check?), or is it more likely to be an actual faulty sensor? It's booked in with my local independent on Monday, but I'd like to have a tinker myself, if I can.
Code: Select all
Monday,16,January,2023,14:31:56:08872
VCDS Version: Release 22.10.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
                Address 34: Level Control       Labels: 4G0-907-553.clb
Control Module Part Number: 4G0 907 553 G    HW: 4G0 907 553 F
  Component and/or Version: LUFE-DAEMPFER H19 0783
           Software Coding: 008003
            Work Shop Code: WSC 02391 785 00200
              ASAM Dataset: EV_AirSuspe 003025 (AU57)
                       ROD: EV_AirSuspe_VW51.rod
3 Faults Found:
677388 - Ride-Height System; Plausibility Error
          C1046 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 220
                    Mileage: 90084 km
                    Date: 2023.01.13
                    Time: 16:02:46
455692 - Sensor for Ride-Height
          C1048 07 [008] - Mechanical Failure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 90077 km
                    Date: 2023.01.13
                    Time: 15:29:47
403200 - Function Shut-Off Active
          C10C8 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 10
                    Reset counter: 220
                    Mileage: 90077 km
                    Date: 2023.01.13
                    Time: 15:28:36
Golfather
Re: Suspension Faults (VCDS)
Post by Golfather » Tue Jan 17, 2023 7:51 pm
Remove the CETE as even in bypass mode signals pass through it.
THen retest.
But with that log looks more like the sensor itself. Get underneath ensure its not a broken link, can clean connector too just incase. Easy enough to repair. Its intermittent so may resolve by doing those steps.
HDPete
Post by HDPete » Wed Jan 18, 2023 12:17 pm
Thanks for the tip. I didn't realise that there was a physical linkage - I'll check that first, as that's most likely popped off from the harsh weather and water I was going through.
I'll report back with findings in case it helps others.
Cheers.
HDPete
Post by HDPete » Fri Jan 20, 2023 5:00 pm
It turns out that the link arm has separated.
I am not certain whether the green plastic has snapped or not. Any idea from the pics? It feels rough inside, but I think it just snaps on. I need to get the wheel off to try, but before I do, I thought I'd get opinion here as whether the parts look normal and not broken.
morski
Post by morski » Fri Jan 20, 2023 6:10 pm
That looks snapped. You have the air suspension lowering links fitted. Green part in the red arm looks like its part of the green arm from the sensor
Golfather
Post by Golfather » Fri Jan 20, 2023 8:15 pm
So you have lowering links AND the Cete fitted ?!
I would remove all those links and put genuine ones back on then use the Cete to control all the lowering.
HDPete
Post by HDPete » Sat Jan 21, 2023 11:00 am
The car suspension is stock - I haven't fitted lowering links and have had the car from new. The links are the ride height sensor connecting rods.
Golfather
Post by Golfather » Sun Jan 22, 2023 11:57 pm
Stock rods are always plastic and fixed length
That looks like red anodised metal and is adjustable:
HDPete
Post by HDPete » Mon Jan 23, 2023 9:13 am
Interesting!! Thank you. It’s off to the garage today so I’ll report back. It’s never had any suspension work done from new, other than the CETE. Curious.
HDPete
Post by HDPete » Mon Jan 23, 2023 10:19 am
Do you know whether a Replacement sensor will need coding in and the ACC systems etc recalibrated, as my local garage won’t be able to do that
Golfather
Post by Golfather » Tue Jan 24, 2023 12:33 am
No it should be plug and play
Users browsing this forum: No registered users and 75 guests
