Over the last few days, I have had a series of warnings which started with a yellow Air Suspension Fault and various related things, like the ACC and Brake Guard disabled. I had just completed a rather wet long distance drive and put it down to water in the electrics somewhere.
The next day, the red Air Suspension Warning came on and I could hear the car rubbing its wheels in the arches. I have a CETE module and have managed to lift the car up again, but the amber fault keeps coming back. The CETE module is in bypass mode, so I don't believe that it is causing the issue.
A VCDS scan reveals the following, which suggests a mechanical sensor fault. It is likely to be water in the plug (and how easy is it to check?), or is it more likely to be an actual faulty sensor? It's booked in with my local independent on Monday, but I'd like to have a tinker myself, if I can.
Code: Select all
Monday,16,January,2023,14:31:56:08872
VCDS Version: Release 22.10.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 34: Level Control Labels: 4G0-907-553.clb
Control Module Part Number: 4G0 907 553 G HW: 4G0 907 553 F
Component and/or Version: LUFE-DAEMPFER H19 0783
Software Coding: 008003
Work Shop Code: WSC 02391 785 00200
ASAM Dataset: EV_AirSuspe 003025 (AU57)
ROD: EV_AirSuspe_VW51.rod
3 Faults Found:
677388 - Ride-Height System; Plausibility Error
C1046 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 220
Mileage: 90084 km
Date: 2023.01.13
Time: 16:02:46
455692 - Sensor for Ride-Height
C1048 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 90077 km
Date: 2023.01.13
Time: 15:29:47
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 220
Mileage: 90077 km
Date: 2023.01.13
Time: 15:28:36
