Please identify these rusty pipes.....
Fil3807
Post by Fil3807 » Wed Nov 02, 2022 9:32 pm
Can anyone tell me what these pipes are for...... I think they need replacing ..... I couldnt believe how they were when I saw them today ....
I know this looks bad hense the post ..... Im well aware its bad.
I hope it holds on for a bit ..... :shock: :shock: :shock: :shock:
Trying to fix issues :?
Regards Phill
Riggs
Re: Please identify these rusty pipes.....
Post by Riggs » Wed Nov 02, 2022 9:52 pm
Hi Phil
They are your engine oil cooler pipes.
Leave them alone until you get some new ones as they will be seized and will strip the threads when you try to get them apart. They will undo fine from the oil filter housing end but not the cooler. If you want to replace them you will end up doing both of them, gearbox/engine oil cooler and both the gearbox oil cooler pipes which are on the other side.
The pipes are no longer available from Audi but oil cooler is and it’s about £1000.
Try RS Carparts in Germany they make the pipes and they are good quality.
Fil3807
Post by Fil3807 » Wed Nov 02, 2022 10:32 pm
Hi Phil
Are they liable to leak or burst .... are they under loads of pressure? Reason I ask is because on Friday we have to make a journey which is about a 100 mile round trip.
Riggs
Post by Riggs » Wed Nov 02, 2022 10:37 pm
I don’t think they will let go as if they were on their way out they would be damp or sweating with oil, they are just abit crusty. they run under whatever oil pressure the engine creates. If they burst it would empty your engine of oil very quickly.
Fil3807
Post by Fil3807 » Thu Nov 03, 2022 12:02 am
Can you link me the the 4 or so pipes I need? cant seem to change site to English....
Steve2003rs6
Post by Steve2003rs6 » Thu Nov 03, 2022 11:06 am
See recent post for intercooler and Vagcom.
Fil3807
Post by Fil3807 » Sun Nov 06, 2022 5:24 pm
Looking at RS Carparts Germany for my replacement lower engine oil lines, if that is the correct name for them?
As you all may have seen my hard pipes are also very rusty! Am I correct in thinking that these new lines wont include ALL the hard lines? Pic one has a part hardline, however as you can see in my picture below the lines run from the braided parts towards the back of the engine. not sure about the other side configuration wise....
I just want to safeguard my engine by ensuring /maintaining oil pressure etc.
These 3 lines also work out very very expensive..... surely there is a more cost affective solution ???? Working it out to be approx £566 imported :shock:
and if thats for mainly just the braided parts then .....WOW!
Any further advice would be greatly appreciated.
Thanks Phill
Astrosquirrel
Post by Astrosquirrel » Sun Nov 06, 2022 6:31 pm
If the pics are anything to by, then I'd say no. Those lines in your pic are these
I may be wrong but replacing those may be a tad difficult. Is that also an engine out jobby? Image
Edit: just checked under the car. They're well reachable though good luck getting a wrench in there... Probably there's a creative way to doing them.
Sent from my 2107113SG using Tapatalk
Fil3807
Post by Fil3807 » Sun Nov 06, 2022 6:48 pm
Thanks for the info, Any part numbers for these?
Also any possibility of a picture of any lines the other if there are any?
Thank you so much.
Astrosquirrel
Post by Astrosquirrel » Sun Nov 06, 2022 6:59 pm
The other side sure you'll see other lines but those go to the box
Part numbers i don't have at hand atm. But I'm sure a quick look at 7zap will render results.
Astrosquirrel
Post by Astrosquirrel » Sun Nov 06, 2022 8:02 pm
I think I found the Part #s:
4B3 317 815 B
4B3 317 815 C
Items #1 and 4 in this link:
https://audi.7zap.com/en/rdw/audi+rs6+r ... -317079/#1
Fil3807
Post by Fil3807 » Sun Nov 06, 2022 8:33 pm
I was just about to send you the same details - many thanks for you help ;) now to find them lol and buy them....
Astrosquirrel
Post by Astrosquirrel » Sun Nov 06, 2022 8:39 pm
No worries. Good luck, hope you find a good deal.
We should really organize a group manufacture/buy of a batch of these at some point :-/
Fil3807
Post by Fil3807 » Sun Nov 06, 2022 9:03 pm
quick thing: did you mean 815C and 816C???
2 LINKS I have open - same year 2003 my previous window states:
4B3 317 815 A
4B3 317 816 B
your link:
4B3 317 815 C
4B3 317 816 C
Confused myself - my car is 10/05/2003 date of first registration.
Astrosquirrel
Post by Astrosquirrel » Sun Nov 06, 2022 10:04 pm
Oops sorry, bit tired.
According to the link I sent, it should be:
4B3 317 815 C
4B3 317 816 C
Or items 1 & 4.
Now in the schema, item 4 (816C) seems to suggest another connection further back, but that pipe isn't tagged. It's tough to say if that's the correct Part #.
Item 1 (815C) is definitely correct according to the diagram
Users browsing this forum: No registered users and 324 guests
