I know this looks bad hense the post ..... Im well aware its bad.
I hope it holds on for a bit .....
Trying to fix issues
Regards Phill
Are they liable to leak or burst .... are they under loads of pressure? Reason I ask is because on Friday we have to make a journey which is about a 100 mile round trip.Riggs wrote: ↑Wed Nov 02, 2022 9:52 pmHi Phil
They are your engine oil cooler pipes.
Leave them alone until you get some new ones as they will be seized and will strip the threads when you try to get them apart. They will undo fine from the oil filter housing end but not the cooler. If you want to replace them you will end up doing both of them, gearbox/engine oil cooler and both the gearbox oil cooler pipes which are on the other side.
The pipes are no longer available from Audi but oil cooler is and it’s about £1000.
Try RS Carparts in Germany they make the pipes and they are good quality.
Thanks for the info, Any part numbers for these?Astrosquirrel wrote: ↑Sun Nov 06, 2022 6:31 pmIf the pics are anything to by, then I'd say no. Those lines in your pic are these
I may be wrong but replacing those may be a tad difficult. Is that also an engine out jobby?
Edit: just checked under the car. They're well reachable though good luck getting a wrench in there... Probably there's a creative way to doing them.
Sent from my 2107113SG using Tapatalk
Users browsing this forum: No registered users and 193 guests
