Vert - soft top open/close on key???
Fatneck73
Post by Fatneck73 » Fri Sep 04, 2020 10:06 am
Anyone know if this is an option?
Jezza1644
Re: Vert - soft top open/close on key???
Post by Jezza1644 » Fri Sep 04, 2020 11:51 am
Un-lock the car. Put the key in lock and turn 90 degrees to right which should put all the windows down. When windows are all down turn key to right again which should trigger roof mechanism and put the roof down.
Hope this helps!
Fatneck73
Post by Fatneck73 » Fri Sep 04, 2020 1:12 pm
Brill ta. Will try that later. Can it not be done or programmed to work from the zapper?
Jezza1644
Post by Jezza1644 » Fri Sep 04, 2020 4:20 pm
Good luck! I don't think you can use the zapper to lower/rasise the hood. Be brilliant if you could though!
sumdy
Post by sumdy » Fri Sep 04, 2020 6:31 pm
I can open close the roof from my fob.
Fitted a small module into wiring behind the off side rear seat panel
opens/closes on fob
no need to hold switch if using when driving, just a flick down or up to activate
and i think it raises the speed to 40 mph if used when moving
check out, mods4cars online
Roj-singh
Post by Roj-singh » Tue Sep 08, 2020 6:17 pm
As sundy says there's a module you can add that gives you that feature otherwise only with key inserted in lock
Fatneck73
Post by Fatneck73 » Tue Sep 08, 2020 8:55 pm
Cheers all
