Vert - soft top open/close on key???
Anyone know if this is an option?
Re: Vert - soft top open/close on key???
Un-lock the car. Put the key in lock and turn 90 degrees to right which should put all the windows down. When windows are all down turn key to right again which should trigger roof mechanism and put the roof down.
Hope this helps!
Hope this helps!
Brill ta. Will try that later. Can it not be done or programmed to work from the zapper?
Good luck! I don't think you can use the zapper to lower/rasise the hood. Be brilliant if you could though!
I can open close the roof from my fob.
Fitted a small module into wiring behind the off side rear seat panel
opens/closes on fob
no need to hold switch if using when driving, just a flick down or up to activate
and i think it raises the speed to 40 mph if used when moving
check out, mods4cars online
opens/closes on fob
As sundy says there's a module you can add that gives you that feature otherwise only with key inserted in lock
Cheers all
Users browsing this forum: No registered users and 39 guests
