Hi guys,
Just looking for a little advise
Does anyone know what pressure the DRC should be running at ??
Thanks in advance
DRC
Re: DRC
15 'reads' Mick and no suggestions...can I ask why you want to know technical data on the DRC#s plumbing? Are you using an independent to verify what the dealer is saying perhaps?
2020 F3 RSQ3 Std, 400PS, Daytona Grey/black Ara blue interior, Pano, C&S pack, Red calipers, HBA, TP monitoring, 5yr Warranty, Cete AVC, EBC Redstuffs
Gone, 2016 8U RSQ3 Performance
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Re: DRC
No it has to be pressurised by the dealer. From memory it is in the order of 20 bar - very high - but your dealer will give you an accurate figure.
Re: DRC
Thanks both, just picked the car up and told the system is at 15bar if drops below 14bar then it will be replaced , I had read that it was pressured at 16bar so wanted to confirm as I now have zero confidence in my dealer.
They have confirmed the noise and said replacement will only happen if a) drops below 14bar (14-15bar min operating pressure, which I find weird on a sealed system. B) if the noise gets unbearable
Rs4Belgium
Re: DRC
had a lot of issues with my DRC. (and still does not have the ride comfort it should have). one advice if it is noisy something is broken! so go ahead with it and do not believe your dealer. Audi knows very well the problem they have with the drc system so if there is noise ---> they need to fix it ( mine they changed 3 times all the valves before "finding" the problem)
