DRC
2.9 V6 24v TFSI - 444 bhp
Gig80
DRC
Post by Gig80 » Fri Apr 12, 2019 3:37 pm
Hi guys,
Just looking for a little advise
Does anyone know what pressure the DRC should be running at ??
Thanks in advance
RS4John
Re: DRC
Post by RS4John » Fri Apr 12, 2019 8:06 pm
15 'reads' Mick and no suggestions...can I ask why you want to know technical data on the DRC#s plumbing? Are you using an independent to verify what the dealer is saying perhaps?
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
PieterZ
Re: DRC
Post by PieterZ » Fri Apr 12, 2019 11:14 pm
I had mine changed out, but I have no idea what pressure they are.
From what I understand it’s a pre pressurised system ready to install? Correct me if I’m wrong.
Basically if it rattles, it’s broken.
All black B9 RS4
Markp
Re: DRC
Post by Markp » Sat Apr 13, 2019 9:32 am
No it has to be pressurised by the dealer. From memory it is in the order of 20 bar - very high - but your dealer will give you an accurate figure.
Gig80
Re: DRC
Post by Gig80 » Sat Apr 13, 2019 10:39 am
Thanks both, just picked the car up and told the system is at 15bar if drops below 14bar then it will be replaced , I had read that it was pressured at 16bar so wanted to confirm as I now have zero confidence in my dealer.
They have confirmed the noise and said replacement will only happen if a) drops below 14bar (14-15bar min operating pressure, which I find weird on a sealed system. B) if the noise gets unbearable
PieterZ
Re: DRC
Post by PieterZ » Sat Apr 13, 2019 11:37 am
On mine they changed out the parts ar least that’s what they told me.
So far so good.
All black B9 RS4
Rs4Belgium
Re: DRC
Post by Rs4Belgium » Thu Oct 24, 2019 8:09 am
had a lot of issues with my DRC. (and still does not have the ride comfort it should have). one advice if it is noisy something is broken! so go ahead with it and do not believe your dealer. Audi knows very well the problem they have with the drc system so if there is noise ---> they need to fix it ( mine they changed 3 times all the valves before "finding" the problem)
Users browsing this forum: No registered users and 70 guests
