JamesBaby’s B7 RS4 Avant Daytona
Re: JamesBaby’s B7 RS4 Avant Daytona
Thanks dude. Looks like a good bit of kit. Presumably it doesn't upset the handling or make the ride too stiff?
Sent from my ONEPLUS A6013 using Tapatalk
Current
'07 - Audi RS4 Avant Daytona Grey
'02 - Audi 8L A3 1.9 TDI (PD)
Gone
'03 Subaru Impreza WRX STI
'96 VW Golf VR6
'91 Toyota MR2 N/A
'90 Peugeot 205 GTI 1.9
'90 VW Mk2 Golf GTI 8V
Gone
'96 VW Golf VR6
'91 Toyota MR2 N/A
Iv just done the exact same job to mines. It doesn't feel much stiffer than standard but definitely tightens things up! Only thing I added in extra to that was new front wheel bearings while I was in there
As above. Doesn’t stiffen anything. Just makes it feel more solid and planted. 4 wheel alignment mandatory.
JamesBaby wrote: ↑Tue May 07, 2019 11:28 pmUpdate. Overhauled the brake calipers, discs and pads.
I bought front discs from Reyland Motorsport for £340 delivered, just before the price change
Thing of beauty these are. You have to use your standard bells from Oem or Brembo aftermarket discs.
I bought new bolts from mtecbrakes.com as my old ones were looking poor. I didn’t want issues when I took them apart and for £6 for 20 it was a no brainier.
https://www.mtecbrakes.com/m6-x-30mm-bo ... asher.html
You can also get the spring clamps and H type bobbins from them too if needed but mine were ok on my bells.
I soaked them all in Bilt Hamber Deoc-C corrosion remover. They came out great. Including the Caliper pins and spring clamps.
I cleaned the hubs until they were surgically clean. Do not put layers of grease or paint etc on hubs. It will cause you run out and vibration issues. Clean, WD40, and leave be.
Being OCD, I don’t like the discs getting a rusty unswept area on the disc face. So I made a mask and painted around 5-7 mm in a circle with high temp silver paint. So hopefully this will keep it silver looking.
I also had the front calipers fully refurbed by Jonny at Brake Caliper Refurbs. They blast them to bare metal, strip all components, replace any defective item, plate all exposed workings, and install new bleed nipples.
I had the standard oem black ones but had them redone in Speed Yellow.
They look well installed.
The rears were also done. I managed to bag a great carparts4less deal on the rear discs.
I bought new calipers for the rear and painted and lacquered them myself.
Some pics of the final install.
I had problems upgrading my brake hoses to stainless braided ones. The hard line connectors are corroded and I damaged a hard line which had to be replaced. So doing the hoses will be revisited at a later date.
I used DS2500 pads and now that everything has some miles on it and bedding in, the bite is nice and sharp and the stopping power is great.
Really helpful stuff here, going through the process of having my discs and pads replaced too. Like you, I got mine from Reyland so passed it onto the garage for them to do the hard work!!
Thanks man. I do love driving it.
So I recently updated the RNS-E with the later LED screen version. It does work and calculate routes much faster. I also got a genuine 2019 map disc.
Then I also changed the I-Pod doc to the AMI module together with a Tune2Air Bluetooth module. Sound quality is better and I can now view track listing directly on the head unit.
I have an iPod dock and Tune2Air Bluetooth module for sake if someone wants to swap out their CD changer for one.
- Weiß-sechs
- Location: Everywhere & nowhere baby, that's where I'm at...
Nice, looks neat.
Prawn cocktail crisps though??
Haha. I’m addicted to crisps.
car looks great! How many miles has it done?
Hit 103k. Just nicely run in.Toady1 wrote:car looks great! How many miles has it done?
Just been on a 2300mile euro trip in it. Didn’t miss a beat.
You’ve got to love it when a high performance car doesn’t skip a beat
B7 RS4 Saloon, Phantom Black, Forge Oil Cooler Kit, 20 x 10.5j Vossens, Carbon Front Splitter, KW V3 Coilovers, Adjustable Front Arms, 20mm Spacers, Revolution Carbon Air Box, B8 RS4 Rear Caliper Plates, Milltek Non Res Non Valved Exhaust, RS6 Gloss Black Grill, Slightly Tinted Windows, JH Motorsports Stage 3R Clutch & Lightweight Flywheel, Robnic Braided Clutch Line. JH Motorsports Lightweight Grooved F & R Rotors with Braided Hoses and Hawk Pads
Wow very impressive and some genuinely good information, I’ve just bought one and I hope I can get it somewhere near as nice as yours.
Andy
Andy
Users browsing this forum: No registered users and 1 guest
