I bought front discs from Reyland Motorsport for £340 delivered, just before the price change
Thing of beauty these are. You have to use your standard bells from Oem or Brembo aftermarket discs.
I bought new bolts from mtecbrakes.com as my old ones were looking poor. I didn’t want issues when I took them apart and for £6 for 20 it was a no brainier.
https://www.mtecbrakes.com/m6-x-30mm-bo ... asher.html
You can also get the spring clamps and H type bobbins from them too if needed but mine were ok on my bells.
I soaked them all in Bilt Hamber Deoc-C corrosion remover. They came out great. Including the Caliper pins and spring clamps.
I cleaned the hubs until they were surgically clean. Do not put layers of grease or paint etc on hubs. It will cause you run out and vibration issues. Clean, WD40, and leave be.
Being OCD, I don’t like the discs getting a rusty unswept area on the disc face. So I made a mask and painted around 5-7 mm in a circle with high temp silver paint. So hopefully this will keep it silver looking.
I also had the front calipers fully refurbed by Jonny at Brake Caliper Refurbs. They blast them to bare metal, strip all components, replace any defective item, plate all exposed workings, and install new bleed nipples.
I had the standard oem black ones but had them redone in Speed Yellow.
They look well installed.
The rears were also done. I managed to bag a great carparts4less deal on the rear discs.
I bought new calipers for the rear and painted and lacquered them myself.
Some pics of the final install.
I had problems upgrading my brake hoses to stainless braided ones. The hard line connectors are corroded and I damaged a hard line which had to be replaced. So doing the hoses will be revisited at a later date.
I used DS2500 pads and now that everything has some miles on it and bedding in, the bite is nice and sharp and the stopping power is great.
