Airbag connector for seats image
Callumrobin
I have different seats converted into my 2006 B7 RS4 Avant, due to this the airbag light is on and was pointed in the direction of SC Tuning in Germany to provide the simulator plugs.
Ordered what I thought was the correct set-up however it appears I have different connectors each side.
My car originally had the bucket seats in, would anyone have a picture of the correct plugs each side on theirs?
Regards
Callum
Regards
Callum
Re: Airbag connector for seats image
Do you mean this plug?
Callumrobin
Is that the car seat side?
That’s the plug under the seat that the seat plugs into . From memory both sides are the same plug but I might be wrong on that
Callumrobin
This was on the passenger side so originally I thought it would be 2 of these, I got 2 male simulator connectors and the passenger one fitted fine.
Drivers side I have this
Callumrobin
Unless I am being thick and there is another connector there somewhere?
I assume you are fitting b7 comfort seats in?
The photo is from when I switched from buckets to comforts on a 06 cab.
Mine was the same connectors on both sets of seats. I did read something about having to fit an adaptor or similar in some circumstances . Try the search function if you haven’t already.
Failing that hopefully someone else with more knowledge will be along shortly.
Callumrobin
Previous owner converted RS5 seats in and I don't really want to change them.
Have tried searching but will keep on looking, thanks for the help.
Callum
Callum
Users browsing this forum: Google [Bot] and 68 guests
