Airbag connector for seats image
Callumrobin
Post by Callumrobin » Mon Feb 19, 2018 2:20 pm
I have different seats converted into my 2006 B7 RS4 Avant, due to this the airbag light is on and was pointed in the direction of SC Tuning in Germany to provide the simulator plugs.
Ordered what I thought was the correct set-up however it appears I have different connectors each side.
My car originally had the bucket seats in, would anyone have a picture of the correct plugs each side on theirs?
Regards
Callum
pete62
Re: Airbag connector for seats image
Post by pete62 » Mon Feb 19, 2018 2:36 pm
Do you mean this plug?
Callumrobin
Post by Callumrobin » Mon Feb 19, 2018 2:39 pm
Is that the car seat side?
pete62
Post by pete62 » Mon Feb 19, 2018 2:42 pm
That’s the plug under the seat that the seat plugs into . From memory both sides are the same plug but I might be wrong on that
Callumrobin
Post by Callumrobin » Mon Feb 19, 2018 2:45 pm
This was on the passenger side so originally I thought it would be 2 of these, I got 2 male simulator connectors and the passenger one fitted fine.
Drivers side I have this
Callumrobin
Post by Callumrobin » Mon Feb 19, 2018 2:46 pm
Unless I am being thick and there is another connector there somewhere?
pete62
Post by pete62 » Mon Feb 19, 2018 3:00 pm
I assume you are fitting b7 comfort seats in?
The photo is from when I switched from buckets to comforts on a 06 cab.
Mine was the same connectors on both sets of seats. I did read something about having to fit an adaptor or similar in some circumstances . Try the search function if you haven’t already.
Failing that hopefully someone else with more knowledge will be along shortly.
Callumrobin
Post by Callumrobin » Mon Feb 19, 2018 3:23 pm
Previous owner converted RS5 seats in and I don't really want to change them.
Have tried searching but will keep on looking, thanks for the help.
Callum
