Had my RS4 Remapped
Had my RS4 Remapped
Hi all,
Was disappointed with the first dyno run as my car only made 380BHP. The mapper assured me this was quite normal on RS's as they lose some power through the gearbox and excess carbon buildup. Is this true?
More importantly my car made 463 BHP after the remap. I was quite impressed. I have a JC weldfab exhaust by the way with downpipes. Car now booked in for a carbon clean so hopefully the car should make at least 485 BHP.
I have attached the graph.
Re: Had my RS4 Remapped
Eh?
380 --> 465 from a map?
Something not right here.
Who mapped it? Did they fix some underlying problem between runs?
2007 RS4 B7 Avant
2007 RS4 B7 Avant
DMS automotive. Highly reputable.
Hiya,
I think there is some plonker pulling going on here
The 465 sounds plausible but starting at 380 no way unless it was a B7 with a carbon clean in between the runs!
Just had mine remapped by MRC and I think it came out about 450 will have a look later. In any case the increase was only about 20bhp from the map, which is probably what was expected.
Did they do the gearbox too?
Oh.. Rule 1
Oh.. Rule 1
2006 RS4 Avant - Carbon Clean, Intake Ports Polished, HF Air Filter, MRC Remap
1998 Toyota Supra 3.0 TT - de-cat, bleed valve, UK Spec Brakes, HKS Springs & CW Dampers, Goodridge Lines, Pagid Pads & 360 RWHP
1990 Toyota Supra 3.0 T - de-cat, HKS Boost Controller (1.4 bar max), used as a daily drive for 110k miles on original turbo!
198x Granada 2.8i Ghia X - Can't remember the exact year - but a great car!
Yea they have just fiddled the transmission losses to show an improvement. Maps on a B8 are 10-20bhp and normally only if you have changed things induction or exhaust side.
Sent from my SM-G935F using Tapatalk
Yep spot on, I got about 20hp with a milly and new high flow air filters, nothing more to be had I'm afraid
Not sounding too reputable given the dodgy dyno figures88LE wrote:DMS automotive. Highly reputable.
2007 RS4 B7 Avant
Have a look at:
http://www.dmsautomotive.com/upgrades/audi-rs4-b8/
Don't forget I do have a full JC Weldfab exhaust system with downpipes. But to be fair I'm doubting the map. Perhaps they did fiddle the transmission losses.
V8mark - So your car before was 430BHP and after the remap went to 450BHP?
OP O/T but you're not over in Dudley (West Mids) are you?
Welcome to the forum btw
RS4.....another
Previous - all sorts
RS4.....another
wheelfurb wrote:Have a look at:
Hiya,
I'll have a look at the Dyno plot later, I think that's about right. It made about stock with a remap!!
Also MRC removed the inlet manifold and there wasn't sufficient carbon buildup to warrant a clean. So looking at your figures you might not need one.
The carbon issue is left over from the old B7, and even then wasn't a problem if driven correctly
Would like to hear your exhaust some time if that's possible??
V8mark wrote:wheelfurb wrote:Have a look at:
Hiya,
Yeah anytime. Just let me know and I'll make sure it's there
Small world, I looked up your place at the beginning of the week for some work. I'll drop you a PM
Max
RS4.....another
RS4.....another
Not many B8s with a weldfab exhaust that I know of. Is this Ross's old car? I know it was bought by a forum member but not sure if he still has it.
