On the passenger side front end every now and again there is a knocking noise. It's not suspension as Drc is removed and coilovers fitted. With the wheel jacked up, if I apply pressure to the wheel side to side I can make it knock. There is a very small amount of movement. Is this likely to be the wheel bearing?
Front end knocking
- SimonS4MTM
- Top Gear
Re: Front end knocking
Side to side not up and down? Maybe track rod?
- Dantheman84
- 1st Gear
Yes possible trackrod or steering rack slightly loose for what it is worth I would check all bolts for suspension and steering subframe then you know they are tight any slightest movement will sound louder in the car has you will also feel it through your feet or steering wheel
RS4 kw v3 full miltek no cats
Intake spacer deflap stage 2 flat shift launch
Kawasaki ZX10R 197bhp
Yeah side to side. Thanks both for your replies, I'll look at those areas.
rickster147
Spin the wheel if you here any grinding noise it's the wheel bearing
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
Previous audi
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 164 guests
