Front end knocking
Rw@@dy
Front end knocking
Post by Rw@@dy » Wed Jun 21, 2017 8:48 pm
On the passenger side front end every now and again there is a knocking noise. It's not suspension as Drc is removed and coilovers fitted. With the wheel jacked up, if I apply pressure to the wheel side to side I can make it knock. There is a very small amount of movement. Is this likely to be the wheel bearing?
SimonS4MTM
Re: Front end knocking
Post by SimonS4MTM » Wed Jun 21, 2017 8:53 pm
Side to side not up and down? Maybe track rod?
Dantheman84
Post by Dantheman84 » Wed Jun 21, 2017 10:55 pm
Yes possible trackrod or steering rack slightly loose for what it is worth I would check all bolts for suspension and steering subframe then you know they are tight any slightest movement will sound louder in the car has you will also feel it through your feet or steering wheel
RS4 kw v3 full miltek no cats :nogarors4:
Intake spacer deflap stage 2 flat shift launch
Kawasaki ZX10R 197bhp :audibash:
Rw@@dy
Post by Rw@@dy » Thu Jun 22, 2017 6:40 am
Yeah side to side. Thanks both for your replies, I'll look at those areas.
rickster147
Post by rickster147 » Thu Jun 22, 2017 7:36 am
Spin the wheel if you here any grinding noise it's the wheel bearing
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
Users browsing this forum: No registered users and 180 guests
