Next RS6... this time in Black. Does anyone know BX**?
RS2
Post by RS2 » Mon May 15, 2017 2:35 pm
Yes, I've gone and done it again... didn't I learn anything last time??
It's yet another dead gearbox'd C5 RS6 but this time... it doesn't move at all no matter which gear you select so I suspect the torque convertor or oil pump.
There are a host of faults in the car so there's work to do.
Does anyone know this car previously?
It's black, black (white pinstripe) interior with carbon effect trim. First registered in Jan 2004 and needs a lot of TLC.
I'd be keen to find out as much as possible about it's history. Yes I did an HPI on it so I know some but it has no service history at all.
I'm wondering where the RS6 door mirrors have gone for one.
MG
Steveo
Re: Next RS6... this time in Black. Does anyone know BX**?
Post by Steveo » Mon May 15, 2017 6:09 pm
Maybe the mirrors are in the gearbox? 😛
RS6 C5, MTM
Mɐʇʇ
Post by Mɐʇʇ » Mon May 15, 2017 9:10 pm
Black is my favourite. Just needs alcantara and Ali interior.
Ajc
Post by Ajc » Mon May 15, 2017 10:02 pm
Have a look on cazana.com . You need to sign up but stick the reg in and it'll give you everything on the net relating to the car including old sale adds , plate transfers, not history ect . Might throw up some clues to its life
Cheers Al
04 c5 rs6 , Ebony Black, Bare shell repaint , Milltek's, PSS9's,Hotchkis Arb's,Gutted precats, hybrid turbos, Bosch 044 ,And an annoying EML light
Nobby
Post by Nobby » Tue May 16, 2017 8:08 am
Looking forward to another epic rebuild thread :)
Daytona RS6 Avant
Gripper1
Post by Gripper1 » Tue May 16, 2017 8:39 am
Way back when I was looking for mine I saw a black RS6 for sale near me which ticked a lot of the boxes.
The reg BX kind of rings a bell and the interior was as you describe. Unfortunately it was for sale in Keighley Trade Centre/Motorhub/whatever they call themselves now. And didn't take it any further.
I may well be talking a totally different car though!
mavada
Post by mavada » Tue May 16, 2017 8:58 am
Yes, and step by step guide with pics please :D
Starting today yes :D
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
RS2
Post by RS2 » Tue May 16, 2017 2:41 pm
Lol they work... I just don't understand why it's got standard plastic A6 mirrors.
I'm not sure that Alcantara would survive around me... ;) I always liked the look of the 'Piano Black' trim but it's rare.
Thanks I'll try that.
Thanks I'll try...
Interesting. The car lived in Blackburn up until 2008 and was serviced by Blackburn Audi. Beyond that I have no service history at all.
I did learn that it was owned by one of the owners of Sigma Cars & Commercials (the owner before the chap I bought it from) but I haven't tried to contact them yet. If they're anything like other car dealers, they'll have thrown everything away that came with the car just in case there's something in there that could come back and bite them!
Ok ok ok... ;)
MG
RS2
Post by RS2 » Tue May 16, 2017 2:53 pm
I popped home at lunch time just to try to get the car parked sensibly on the drive. It was just rolled off the recovery truck at 5am and I went to bed.
These cars weigh a lot! I ended up using every possible tool that I could just to move it back (uphill) by hand and then jacked the back end up and slid it across using my high-lift trolley jack.
Then I spent a few minutes plugged in looking at Vag-com measuring blocks.
The gear selection that the ECU sees isn't instant when going into Reverse, there's a delay where it reads just a couple of lines and then after a few seconds, 'R' comes up. Neutral initially comes up as Z2 and S comes up as Z4 before switching to S. One of the fault codes was for the Range Sensor so I think I'll put that on the list!
Another fault that was there was the oil temp sensor. While watching the readings, I noticed that with the engine running, the gearbox oil temp was flicking between 19 and 20oC and never went above that. My experience previously is that it climbs steadily. Another thing to add to the list although I think that this is part of the wiring loom that sits in the oil.
The other fault code that's present is the normal one of 'Gear Ratio Monitoring' - 'Incorrect Gear Ratio'.
I wonder if there's any oil in it!
MG
Mɐʇʇ
Post by Mɐʇʇ » Tue May 16, 2017 2:56 pm
What's your plan? Do it up to keep? Do it up to move on? Do it up because you like inflicting pain on yourself etc?
Post by Shoppinit » Tue May 16, 2017 2:58 pm
Yup, F125 without a doubt.
Or if no oil is pumped around, then there's no transfer of heat to the sensor which could be working fine.
Maybe not. Worth checking before doing anything else.
Post by Shoppinit » Tue May 16, 2017 3:01 pm
Here's a scenario that's not too far-fetched:
1. Car develops gearbox fault. F125 breaks and car goes into limp.
2. Owner takes it to garage who incorrectly diagnose it and suggest ATF change.
3. ATF incorrectly done, fluid level way too low.
4. Garage says "not our fault, there was always a chance that the ATF change wouldn't fix it. You need a new box."
5. Owner says, "screw that" and sells it to MG for peanuts.
6. MG puts a couple of litres of ATF in, changes the F125 and it's as good as new.
mavada
Post by mavada » Tue May 16, 2017 3:15 pm
Sorted.
But to have a proper diy he has to take the box out anyway.
Yellow Koni's
Mɐʇʇ
Post by Mɐʇʇ » Tue May 16, 2017 3:25 pm
Wouldn't that be a result! I wouldn't bet my lifesavings on it though.
Post by Shoppinit » Tue May 16, 2017 3:32 pm
C5 RS6 owners don't have any life savings.
Users browsing this forum: Google [Bot] and 83 guests
