Speed recognition - almost there
I have been trying to get traffic sign recognition working in the HUD via VCDS but to no avail. However, tonight it very briefly flashed up a 10mph sign which is correct for the area I was in (a school car park), so it saw 'something'. However it has never come up before or after, so I'm obviously missing a key setting.
If anyone has this as an option and has a dump from VCDS, could you possibly send it to me so I can compare my tweaks?
Pete
Pete
Re: Speed recognition - almost there
Good luck, but I am afraid that, when you do get it working, you will find it is rubbish. The system is often wrong and cannot be relied upon at all.
Do you already have speed recognition and just want it to work on the HUD or you don't have it at all and are trying to get it to work on the DIS and HUD?
FWIW, I was looking to retrofit the speed recognition but everyone on here that had it said it was crap and I they wished they could just use the map speed instead so I didn't bother with it.
- feeltheburn
Have you seen the information here:hdpete wrote: ↑Fri May 05, 2017 9:00 pmI have been trying to get traffic sign recognition working in the HUD via VCDS but to no avail. However, tonight it very briefly flashed up a 10mph sign which is correct for the area I was in (a school car park), so it saw 'something'. However it has never come up before or after, so I'm obviously missing a key setting.
Pete
http://obdeleven.proboards.com/thread/1 ... ptations?
The first post mentions the Sign recognition codes. Intially I wanted to enable this feature- however many have mentioned that although a good idea the Audi implementation is not that reliable. I am overseas for the next couple of years and away from the love of my life ( ..and the wife!) so I haven't been able to explore if the obdeleven adaptation codes will actually work. I guess it just needs to be confirmed whether obdeleven is based on VCDS tech (then the coding should be good) or whether it is VCP based and then it might not be possible to implement via VCDS. I have VCDS but would consider getting the obdeleven interface (VCP?) if it opens up even more features in my car (and way cheaper if you an android phone or can get access to one)
RS6 C7 (2014), Daytona Pearl, 21" Titanium, On Air, LEDs, Sports Exhaust, Dynamic Steering, Red Calipers, ACC, Top View, Connect, Tints, Rear Side Airbags, Rear heated seats; MP4S
I find it very good actually. Maybe it's improved on the facelift? Mine definitely uses map data as well as camera data.
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
Previous:
Yes it used map data unless there was a sign to override the map speed such as you would find through roadworks but the problem was that it was misreading signs and incorrectly changing the speed.
Are we talking about the speed limit display? If so my car gets it wrong a lot! There is a road local to me which was changed from a 60 zone to a 40 zone ages ago and the car still says 60 even after I updated the nav?
Current - 2017 Nardo RS5
tartan_rob
I had this on my X6M and I must be honest, it was very reliable.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
...at the sacrifice of your indicators not working?tartan_rob wrote: ↑Mon May 08, 2017 5:59 pmI had this on my X6M and I must be honest, it was very reliable.
tartan_rob
Nope. It was pretty good, reflected on HUD as well. Worked well, maybe a few metres delay only.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Swing and miss.tartan_rob wrote: ↑Mon May 08, 2017 8:06 pmNope. It was pretty good, reflected on HUD as well. Worked well, maybe a few metres delay only.
dougle_turbo
lolbam_bam wrote: ↑Mon May 08, 2017 9:44 pmSwing and miss.tartan_rob wrote: ↑Mon May 08, 2017 8:06 pmNope. It was pretty good, reflected on HUD as well. Worked well, maybe a few metres delay only.
2010 987 Cayman S.
Clio 172 Cup track car "Nicole" aka NV2 Sold
Clio 172 Cup track car "Nicole" aka NV1 - R.I.P
2007 Phantom black RS4 avant - with added ceramics. Sold
2006 Phantom black RS4 saloon. Sold
1990 Black Audi S2 (3B) - full engine rebuild. Sold
1981 Black Porsche 924 Turbo, rescued from under a tree and restored. Sold
Ha made me chucklebam_bam wrote: ↑Mon May 08, 2017 9:44 pmSwing and miss.tartan_rob wrote: ↑Mon May 08, 2017 8:06 pmNope. It was pretty good, reflected on HUD as well. Worked well, maybe a few metres delay only.
PING! That's the sound of Bam's joke ricocheting around the room above Tartan_Robs head
Current:
Former:
2016 R8 V10 Plus.
2019 E63s AMG 4Matic Estate.
2017 BMW M3 Competition Pack.
2015 A45 AMG.Overrated POS.
2016 C7 RS6 Panther black.
2006 BMW Z4M Roadster.
2004 Alpina Roadster.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
tartan_rob
Just got it. Very funny.
I hate to say it but I was an Audi driver in a BMW....That maybe worse..?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Users browsing this forum: Google Adsense [Bot] and 66 guests
