Has anyone actually fixed this gearbox fault yet?
Right I have the lit up PRNDS when starting sometimes, if it happens I just turn off and restart and PRNDS is back to normal and car drives fine. I've done a search and several people have had the same fault code but no one seems to have fixed it yet.
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1315
Coding: 00001
Shop #: WSC 00000
VCID: 6CDDC7191CD6B72125-5120
1 Fault Found:
18243 - Pressure Control Valve 5 (N233)
P1835 - 35-10 - Short to Plus - Intermittent
Gearbox was reconditioned at Unit 20 12000 miles ago, F125 switch a few months ago and TCU is dry but I did have to re solder some joints a while back.
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Re: Has anyone actually fixed this gearbox fault yet?
Aren't the looms in the Box a common fault and prone to issues due to heat cycling and the fluid? .I would look at a wiring fault myself as it's intermittent . Though I'm sure shopp will correct me in a minute
Cheers Al
04 c5 rs6 , Ebony Black, Bare shell repaint , Milltek's, PSS9's,Hotchkis Arb's,Gutted precats, hybrid turbos, Bosch 044 ,And an annoying EML light
If it is complaining about the pressure control valve (isn't that just a fancy name for a solenoid? ) then I'd be changing that and also checking the fluid level and making sure there aren't any leaks.
Is it worse in any particular type of weather or when it's been used a lot or left standing?
Good chance the loom has failed inside the box, pretty sure they go brittle over time. Sump has to come off either way, so can then check the solenoids at the same time.
Maybe weak battery and / or corroded 200A fuse cause the fault condition when cranking. Try starting it with another fully charged battery connected with jumper cables.
Or could be wiring as already mentioned. You could check the connector to the box for corrosion, too.
I've Removed and cleaned the two maxi fuses in the plenum recently they weren't to bad as I keep an eye on the drains. I have an AA warranty but they don't cover wiring faults so might get the control valve changed and pay for the loom.
I had the same fault, and it turned out to be my Ecu . Search my threads and all will be explained (well in case of my issue)
TCU is over a £1000 from TPS
any one got a spare I could try?
I could give you my humped one and if comes up with a short to plus on either 2 or 3 and not 5 then to me me that would suggest the tcu. I checked the loom for resistance and replaced the box loom, but evidently it was the tcu. If your handy with a multi Meter, get a copy of elsa win and that will give you a procedure for fault finding. Drop matV8 a line
^good idea.
I have Elsawin, will get the multimeter out then.
Pretty sure the resistance has to be under 8ohm on the 16 pin plug. If it looks dry and clean when you take it out I would be surprised if it's the loom
Users browsing this forum: No registered users and 239 guests
