Has anyone actually fixed this gearbox fault yet?
bilko1
Post by bilko1 » Thu Apr 27, 2017 10:08 pm
Right I have the lit up PRNDS when starting sometimes, if it happens I just turn off and restart and PRNDS is back to normal and car drives fine. I've done a search and several people have had the same fault code but no one seems to have fixed it yet.
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1315
Coding: 00001
Shop #: WSC 00000
VCID: 6CDDC7191CD6B72125-5120
1 Fault Found:
18243 - Pressure Control Valve 5 (N233)
P1835 - 35-10 - Short to Plus - Intermittent
Gearbox was reconditioned at Unit 20 12000 miles ago, F125 switch a few months ago and TCU is dry but I did have to re solder some joints a while back.
Ajc
Re: Has anyone actually fixed this gearbox fault yet?
Post by Ajc » Thu Apr 27, 2017 11:09 pm
Aren't the looms in the Box a common fault and prone to issues due to heat cycling and the fluid? .I would look at a wiring fault myself as it's intermittent . Though I'm sure shopp will correct me in a minute :audibash: :biggrin3:
Cheers Al
srichards
Post by srichards » Fri Apr 28, 2017 12:31 am
If it is complaining about the pressure control valve (isn't that just a fancy name for a solenoid? ) then I'd be changing that and also checking the fluid level and making sure there aren't any leaks.
Is it worse in any particular type of weather or when it's been used a lot or left standing?
Post by chunky79 » Fri Apr 28, 2017 6:29 am
Good chance the loom has failed inside the box, pretty sure they go brittle over time. Sump has to come off either way, so can then check the solenoids at the same time.
Post by Shoppinit » Fri Apr 28, 2017 7:09 am
Maybe weak battery and / or corroded 200A fuse cause the fault condition when cranking. Try starting it with another fully charged battery connected with jumper cables.
Or could be wiring as already mentioned. You could check the connector to the box for corrosion, too.
bilko1
Post by bilko1 » Fri Apr 28, 2017 8:40 am
I've Removed and cleaned the two maxi fuses in the plenum recently they weren't to bad as I keep an eye on the drains. I have an AA warranty but they don't cover wiring faults so might get the control valve changed and pay for the loom.
simors6
Post by simors6 » Fri Apr 28, 2017 11:59 am
I had the same fault, and it turned out to be my Ecu . Search my threads and all will be explained (well in case of my issue)
bilko1
Post by bilko1 » Sat Apr 29, 2017 8:46 am
TCU is over a £1000 from TPS :( any one got a spare I could try?
simors6
Post by simors6 » Sat Apr 29, 2017 9:32 am
I could give you my humped one and if comes up with a short to plus on either 2 or 3 and not 5 then to me me that would suggest the tcu. I checked the loom for resistance and replaced the box loom, but evidently it was the tcu. If your handy with a multi Meter, get a copy of elsa win and that will give you a procedure for fault finding. Drop matV8 a line
Post by Shoppinit » Sat Apr 29, 2017 9:37 am
^good idea.
bilko1
Post by bilko1 » Sat Apr 29, 2017 10:35 am
I have Elsawin, will get the multimeter out then.
simors6
Post by simors6 » Sat Apr 29, 2017 10:55 am
Pretty sure the resistance has to be under 8ohm on the 16 pin plug. If it looks dry and clean when you take it out I would be surprised if it's the loom
Users browsing this forum: No registered users and 112 guests
