New battery time
daytonamart
New battery time
Post by daytonamart » Fri Mar 03, 2017 8:51 pm
As my car was 10 years old on the 1st of March I treated it to a new battery.
Exciting times,
Sorry chaps this is one dull post. :drink:
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
Daytona
Re: New battery time
Post by Daytona » Fri Mar 03, 2017 9:54 pm
Me too, just before Christmas, a Varta AGM type, wasn't cheap!
pule333
Post by pule333 » Fri Mar 03, 2017 11:31 pm
Relatives??? ;)
RS4 B7 aka Vinnie
BenHol
Post by BenHol » Fri Mar 03, 2017 11:33 pm
I put a AGM on. It's been spot on since
RS4 B7 - Phantom Black, 20in RS6 C7 alloys, Joey mod, detango, led drl, black optics, Bilstein b16, Michelin ps4s, centre res delete, black tips, 8mm spacers, vx lenses, RS embossed xenon, Carbon splitter, 034 ARB.
max_b
Post by max_b » Fri Mar 03, 2017 11:39 pm
Relatives??? ;)
:lol:
RS4.....another :-)
Previous - all sorts
irn_bru_ce
Post by irn_bru_ce » Sat Mar 04, 2017 1:40 pm
Is VCDS required to code in the new bettery, read somewhere a while ago that the serial number of the battery needed to be put into the car
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
Post by MikeFish » Sat Mar 04, 2017 1:43 pm
Not on the B7.
daytonamart
Post by daytonamart » Sat Mar 04, 2017 6:46 pm
Pretty straight forward swap over, no coding needed.
I put a Varta I1 (£118 delivered)back in, two issues were the weight of the battery (25kg) combined with reaching in to get the old one out and the key had lost it's syncronisation.
Luckily I read on here how to re-sync so no issue.
Btw it's push close on the fob, put key in ignition, turn on ignition, wait a few seconds, turn off ignition, remove key and push lock car. Done.
beesheppy
Trader (Expired)
Post by beesheppy » Sat Mar 04, 2017 7:41 pm
As in it wouldn't lock unlock via the fob? Or read key in ignition?
My battery has been out over winter but my car locks via the clifford fob
Post by MikeFish » Sat Mar 04, 2017 7:47 pm
Normally the key fob stops locking or unlocking the doors. Can still unlock using the key blade in the lock and still start the car.
jonytek
Post by jonytek » Sat Mar 04, 2017 8:14 pm
I had this after the battery was disconnected for a week.
BUILD THREAD
IG: @bad_rs_4
pule333
New battery time
Post by pule333 » Sun Mar 05, 2017 9:44 am
What I really want to know is, does a lighter alternative to 25kg "ballast" in the boot even exists?? I mean same spec and size.... I know you can get much lighter racing batteries but that's not what I am asking..
RS4 B7 aka Vinnie
daytonamart
Post by daytonamart » Sun Mar 05, 2017 12:09 pm
Good question, I think it's time to 'fess up.
I actually had to get the missus to help me get the old one out, handle each job done.
Do I need to hand my man card in?
DavidRS4
Post by DavidRS4 » Sun Mar 05, 2017 12:14 pm
Definitely!
pule333
Post by pule333 » Sun Mar 05, 2017 12:19 pm
daytonamart wrote:Good question, I think it's time to 'fess up.
Well probably should not have mentioned the missus :) ha ha.
RS4 B7 aka Vinnie
Users browsing this forum: No registered users and 353 guests
