Adjusting rear bilstein coilovers
Is there any easy way to adjust the ride height of the bilstein rear coilovers without dropping the whole rear arm...
Chris
Chris
2007 black RS4 saloon. Bilstein Coilovers, MRC Re-map, Miltek non resonated valved exhaust with de-cats, Gruppe-M carbon induction, JHM manifold spacers, Stage 2 manifold, cold air feed.
Re: Adjusting rear bilstein coilovers
Yes! Blood, sweat, and tears....Frostie wrote:Is there any easy way to adjust the ride height of the bilstein rear coilovers without dropping the whole rear arm...
Chris
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
pule333 wrote:Yes! Blood, sweat, and tears....Frostie wrote:Is there any easy way to adjust the ride height of the bilstein rear coilovers without dropping the whole rear arm...
Chrisand plenty of swearing
Just as i feared...
B14 or B16??? Need plenty of lube on the treads. Had to slightly modify the keys supplied to be able to use with 20mm wrench as extension...
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
B14... Just the basic ones.
That's all you need on the Rs4 trust me
best setting anyways.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
It seems that when trying to adjust with the spanners, there is too much pressure on the spring to allow the thread to move...
Hence why you need extra leverage and more lubeFrostie wrote:It seems that when trying to adjust with the spanners, there is too much pressure on the spring to allow the thread to move...
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Thanks lolpule333 wrote:Hence why you need extra leverage and more lubeFrostie wrote:It seems that when trying to adjust with the spanners, there is too much pressure on the spring to allow the thread to move...
It's a pig of a job. Instead of dropping the sub frame. I drilled a small hole straight through the threaded spring holder and welded a long thin metal tool to slide in and hold it in position. Then a lot of patience doing little quarter turns.
RS4 B7 - Phantom Black, 20in RS6 C7 alloys, Joey mod, detango, led drl, black optics, Bilstein b16, Michelin ps4s, centre res delete, black tips, 8mm spacers, vx lenses, RS embossed xenon, Carbon splitter, 034 ARB.
Just realised that didn't sound right. I made a removable tool and didn't weld anything to the spring seat or thread.
Thanks for the info
I'm looking to install my b14's in the next week or so. Judging by this thread the rears are a pita so I'm hoping to get them set to the right hight before fitting them.
I want to run it pretty low, does anyone know where i should be looking to set them? Also, how much will they settle once fitted?
I'll have a look where mine are tomorrow and let you know.
Thanks Frostie....Frostie wrote:I'll have a look where mine are tomorrow and let you know.
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 124 guests
