Adjusting rear bilstein coilovers
Frostie
Post by Frostie » Sun Jan 01, 2017 6:51 pm
Is there any easy way to adjust the ride height of the bilstein rear coilovers without dropping the whole rear arm...
Chris
2007 black RS4 saloon. Bilstein Coilovers, MRC Re-map, Miltek non resonated valved exhaust with de-cats, Gruppe-M carbon induction, JHM manifold spacers, Stage 2 manifold, cold air feed.
pule333
Re: Adjusting rear bilstein coilovers
Post by pule333 » Sun Jan 01, 2017 6:53 pm
Frostie wrote:Is there any easy way to adjust the ride height of the bilstein rear coilovers without dropping the whole rear arm...
Chris
Yes! Blood, sweat, and tears.... :) and plenty of swearing
RS4 B7 aka Vinnie
Frostie
Post by Frostie » Sun Jan 01, 2017 6:54 pm
Chris
Just as i feared... :audibash:
pule333
Post by pule333 » Sun Jan 01, 2017 7:21 pm
B14 or B16??? Need plenty of lube on the treads. Had to slightly modify the keys supplied to be able to use with 20mm wrench as extension...
RS4 B7 aka Vinnie
Frostie
Post by Frostie » Sun Jan 01, 2017 7:23 pm
B14... Just the basic ones.
pule333
Post by pule333 » Sun Jan 01, 2017 7:24 pm
That's all you need on the Rs4 trust me ;) best setting anyways.
RS4 B7 aka Vinnie
Frostie
Post by Frostie » Sun Jan 01, 2017 7:25 pm
It seems that when trying to adjust with the spanners, there is too much pressure on the spring to allow the thread to move...
pule333
Post by pule333 » Sun Jan 01, 2017 7:28 pm
Frostie wrote:It seems that when trying to adjust with the spanners, there is too much pressure on the spring to allow the thread to move...
Hence why you need extra leverage and more lube Image
RS4 B7 aka Vinnie
Frostie
Post by Frostie » Sun Jan 01, 2017 7:30 pm
Thanks lol
BenHol
Post by BenHol » Sun Jan 01, 2017 7:53 pm
It's a pig of a job. Instead of dropping the sub frame. I drilled a small hole straight through the threaded spring holder and welded a long thin metal tool to slide in and hold it in position. Then a lot of patience doing little quarter turns.
RS4 B7 - Phantom Black, 20in RS6 C7 alloys, Joey mod, detango, led drl, black optics, Bilstein b16, Michelin ps4s, centre res delete, black tips, 8mm spacers, vx lenses, RS embossed xenon, Carbon splitter, 034 ARB.
BenHol
Post by BenHol » Sun Jan 01, 2017 7:55 pm
Just realised that didn't sound right. I made a removable tool and didn't weld anything to the spring seat or thread.
Frostie
Post by Frostie » Sun Jan 01, 2017 7:56 pm
Thanks for the info
Starry
Post by Starry » Sun Jan 01, 2017 11:42 pm
I'm looking to install my b14's in the next week or so. Judging by this thread the rears are a pita so I'm hoping to get them set to the right hight before fitting them.
I want to run it pretty low, does anyone know where i should be looking to set them? Also, how much will they settle once fitted?
2006 RS4
Phantom black
MRC Stage 2, Milltek non res, pre cat delete,
Frostie
Post by Frostie » Mon Jan 02, 2017 12:41 am
I'll have a look where mine are tomorrow and let you know.
Starry
Post by Starry » Mon Jan 02, 2017 7:32 am
Frostie wrote:I'll have a look where mine are tomorrow and let you know.
Thanks Frostie....
2006 RS4
Phantom black
Users browsing this forum: Google [Bot] and 112 guests
