Ok I've a problem with my Bluetooth worked fine the other day connected a few times and made calls over the past few days, today nothing the phone won't see the car. Not a phone problem it sees and pairs with my wife's S3 also no VCDS errors on the Bluetooth module.
Any ideas chaps?
RNSE Bluetooth worked yesterday
- PetrolDave
Re: RNSE Bluetooth worked yesterday
It's not uncommon for the Bluetooth module (which is not part of the RNS-E, it's a separate module under the front seat) to "lock-up" and need a complete reboot - by removing the relevant fuse, waiting a minute or so and replacing the fuse.
Less common is for the BT module to store a blocking fault code - which needs VCDS to check/clear.
Even less common, if you have the K suffix module that has a firmware problem that causes it to fail - but all those should have been replaced under warranty.
Thanks Dave. I'll take a look for the fuse.
I've no fault codes so I'll check the revision number to be sure.
All reset and good to go.
- PetrolDave
No worries, glad to be able to help.weekenny wrote:All reset and good to go.
