RNSE Bluetooth worked yesterday
weekenny
Post by weekenny » Tue Jul 19, 2016 9:21 pm
Ok I've a problem with my Bluetooth worked fine the other day connected a few times and made calls over the past few days, today nothing the phone won't see the car. Not a phone problem it sees and pairs with my wife's S3 also no VCDS errors on the Bluetooth module.
Any ideas chaps?
PetrolDave
Re: RNSE Bluetooth worked yesterday
Post by PetrolDave » Wed Jul 20, 2016 8:28 am
It's not uncommon for the Bluetooth module (which is not part of the RNS-E, it's a separate module under the front seat) to "lock-up" and need a complete reboot - by removing the relevant fuse, waiting a minute or so and replacing the fuse.
Less common is for the BT module to store a blocking fault code - which needs VCDS to check/clear.
Even less common, if you have the K suffix module that has a firmware problem that causes it to fail - but all those should have been replaced under warranty.
weekenny
Post by weekenny » Wed Jul 20, 2016 9:05 am
Thanks Dave. I'll take a look for the fuse.
I've no fault codes so I'll check the revision number to be sure.
weekenny
Post by weekenny » Wed Jul 20, 2016 9:38 pm
All reset and good to go.
PetrolDave
Post by PetrolDave » Thu Jul 21, 2016 2:28 pm
weekenny wrote:All reset and good to go.
No worries, glad to be able to help.
Return to “Electrical”
