Uneven ride height
bem_ho
Uneven ride height
Post by bem_ho » Tue May 10, 2016 4:30 pm
Last month, I have purchased a 2015 RS6 with 4,000km on the clock. The car has DRC suspension and I realised there is ride height difference between the left and the right rear of the car. Is it a common issue for our car with DRC suspension?
I have lowered the car yesterday with H&R 28828-1 20mm springs set and the ride height difference is still there. Is there any fix or it is a normal? I have read a few post on the Internet, with the ride height difference but all within the factory allowance.
Any ideas? Thanks in advance!
Left Rear
Right Rear
wildbore
Re: Uneven ride height
Post by wildbore » Tue May 10, 2016 5:24 pm
It's under warranty so I would take it to a dealer. It's their problem, although they might blame it on your spring kit rather than the DRC.
doodlebug
Post by doodlebug » Tue May 10, 2016 5:38 pm
Agreed, put it back as was otherwise the dealer response is an easy one.
RS6chris!
Post by RS6chris! » Tue May 10, 2016 6:16 pm
Mine looked a bit wonky like that after I jacked it up to take wheels on/off.
Settled as soon as I fired it up and drove a few yards.
Audi will laugh you out the door of you take it in againest warranty with a after market springs on.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Post by MikeFish » Tue May 10, 2016 6:24 pm
Mine is uneven front to rear with the rear sitting high. Some cars seem to do this and other dont.
Surrey Sam
Post by Surrey Sam » Tue May 10, 2016 6:28 pm
I must say, that difference does look a little excessive from RH side to LH side.
RS6chris!
Post by RS6chris! » Tue May 10, 2016 8:45 pm
Does DRC need recharging or re calibrating if you fit lowering springs?
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Andy_W
Post by Andy_W » Tue May 10, 2016 9:27 pm
Isn't the DRC just linked oil reservoirs on the dampers. Wouldn't effect ride hight? Got to be either Spring sag (not as you have changed them) or some sort of weight imbalance in the car?
marc1
Post by marc1 » Tue May 10, 2016 9:40 pm
Take it back to Audi. Clearly it's unfinished you can tell because there is no top coat paint.
Sorry!
zebede
Post by zebede » Tue May 10, 2016 9:42 pm
Gentlemen (and ladies just in case)
In the spirit of science I have just gone outside and got the motor from the garage and had a look, on level ground with a laser level, my car is as near as damnit 403-5mm from the centre of the hub to the wheel arch on a (lasered) level line.....
What's yours??!!?
Zebede
911 C4s cab - summer is fun :D
Panamera Turbo - fully loaded - gone
RS6 C7 - Panther Black - dodgy steering
911 GT3 - awesome but ate tyres
RS4 b8 - Black on Black with Black windows
911 Targa 4s 991 - Black with Grey Leather
innercry666
Post by innercry666 » Tue May 10, 2016 9:45 pm
It's likely to be the DRC pressure. I've had the same issue on my RS4 with the rear right 'sagging'. The last time I had the car aligned it was noted that there had been a loss in ride height over time, presumably due to pressure loss. I've had the DRC pressure recharged and it resolved it for a period of time, so will be going back sometime soon...
RS6 PE - Current
RS4 (B8.5) 2015 - Sold
Focus ST170 - Garaged
Post by MikeFish » Tue May 10, 2016 10:17 pm
Checked mine for side to side difference by eye and it looks ok.
classba
Post by classba » Tue May 10, 2016 10:49 pm
DRC pressure must be checked and adjusted if you have lowered the car.
bem_ho
Post by bem_ho » Wed May 11, 2016 12:07 am
innercry666 wrote:It's likely to be the DRC pressure. I've had the same issue on my RS4 with the rear right 'sagging'. The last time I had the car aligned it was noted that there had been a loss in ride height over time, presumably due to pressure loss. I've had the DRC pressure recharged and it resolved it for a period of time, so will be going back sometime soon...
So the DRC needs to be recharged periodically?
bem_ho
Post by bem_ho » Wed May 11, 2016 12:11 am
Also, some say I might have problem my geometry at the rear that may affect the ride height too.
