Good morning
I'm hoping someone can help me
I have a 2014 RS4 that has a hesitation on part throttle openings at around 2-3000rpm.mits bloody irritating.
Wider throttle openings are fine - it pulls cleanly. But on a part throttle in a higher gear it's a few seconds of stuttering...
It's been in the dealers this week as I had a sport differential failure warning. It's also had an annoying fault that it drops into sports mode on its own - that's usually followed by a more serious misfire/hesitation
I had the Audi assist people out when the diff warning came on and the car had an error log of communication error?
Audi's view on the hesitation - it's a characteristic Of the engine. I think that's boll**ks - unless it's a mapped in problem to reduce with noise or emissions at a point where it measured by some ridiculous European Union directive. In all fairness to the dealer they have taken off the inlet manifold to check for problems but nothing obvious.
Anyone else had this?
Is it a characteristic of the engine?
Rob
Rs4 hesitation around 2-3000 rpm part throttle openings
Lady Penelope
- 2nd Gear
Re: Rs4 hesitation around 2-3000 rpm part throttle openings
It isn't the beginning of a brake or clutch switch fail is it? When the brakes are applied the RS4 automatically decreases the revs. If the switch (£40 fitted) starts to fail as mine did it will intermittently start to decrease revs as you accelerate in the higher gears, usually around 2000 revs.
Might be nothing to do with this but sounds a little familiar. Started every now and again on mine and was bloody annoying and then alarming.
Good luck!
Good luck!
RS4 B7 2007 Cabriolet Misano Red
Revolution carbon air intake, KW adjustable springs, Da Vinci 20" summer rims, OEM 19" winter chrome and black rims, Audi Ceramic front brakes, Milltek cat back non resonated valved exhaust, US spec black front grill, MRC stage 2, Piano black interior + cream leather buckets. EM Tuning dragon eyes and xenon upgrade, TTRS FBMF steering wheel, TV, Reversing camera, Nav, Red leather fitted luggage.
Yep, mine does it, and so did another one that Audi lent me. So, annoying as it is I'd say its a characteristic, probably to do with emissions as you say.
2018 B9 Audi RS4 Carbon Edition
2017 Alfa Romeo Giulia Quadrifoglio
2014 B8 Audi RS4
2013 BMW 330d xDrive, lasted 10 months, worst car ever!
2011 B8 Audi S4
2008 Audi S3
2014 B8 Audi RS4
2011 B8 Audi S4
2008 Audi S3
Has anyone ever got any resolution to the hesitation issue or is it a "characteristic" of the engine?
I have just got a 2014 RS4 and it does the exact same thing so I'm keen to understand whether there's an issue or if it's something I just have to put up with.
A characteristic of the engine ???
Bollocks should be silky smooth from start to finish IMO
At the price of those cars I'd want it sorted !!
Good luck with the dealer
Mine does it sometimes when you boot between 2500 and 4000 and after that all ok it's smooth running
rs4 b8 Suzuka, grey 14
