RS6 390mm Discs
nutter69
RS6 390mm Discs
Post by nutter69 » Mon Sep 07, 2015 10:09 pm
anyone got the part numbers handy?
Rick_RS4
Re: RS6 390mm Discs
Post by Rick_RS4 » Mon Sep 07, 2015 10:29 pm
cant make it out, i can go look inthe garage tomorrow
they dont really fit tho is it for the b7?
nutter69
Re: RS6 390mm Discs
Post by nutter69 » Mon Sep 07, 2015 11:12 pm
yea...
going to make a bracket for the calliper so its spaced right... it fits the hub I'm guessing the calliper is in the wrong position
Rick_RS4
Re: RS6 390mm Discs
Post by Rick_RS4 » Mon Sep 07, 2015 11:42 pm
nutter69 wrote:yea...
with a 4mm 0r 5mm spacer behind the disk on the hub it will fit or grind away the nub on the suspension leg,
you will get alot of inside disk that isnt on contact with the pad tho
Re: RS6 390mm Discs
Post by bam_bam » Tue Sep 08, 2015 10:52 am
The pad sweep on that is gunna be <beep>!
buy a set of C6 callipers to go with them.
RossDagley
Re: RS6 390mm Discs
Post by RossDagley » Tue Sep 08, 2015 11:52 am
Part number is 4F0615301L
They aint small...
The additional unsprung weight and moment of inertia costs will be crippling. Bad idea.
Previously:
JCviggen
Re: RS6 390mm Discs
Post by JCviggen » Tue Sep 08, 2015 12:56 pm
RossDagley wrote: The additional unsprung weight and moment of inertia costs will be crippling. Bad idea.
This.
But are we talking performance here or "looks"? Plenty of people going for 20 inch wheels too even though it makes pretty much everything worse.
The RS4 brake disc size is fine. The calipers are fine, too. If you want to improve braking performance you need:
- Proper brake pads (not EBC, be prepared to spend some money)
- Brake discs with proper cooling vanes in them. The stock discs don't have any.
That's what I will do when I start tracking the car. For road use, just using decent pads will go a long way. If we're talking aesthetics then that's a different matter.
981 Cayman GTS Gray/Orange.
My youtube
nutter69
Re: RS6 390mm Discs
Post by nutter69 » Tue Sep 08, 2015 7:13 pm
Yea dude i know the implications I'm a race technician by trade so know what is required for a performance based improvement..
i have seen a company called giro disc.. they do 380mm discs and you get the spacers too required to space the calliper out..
anyone use these?
Re: RS6 390mm Discs
Post by MikeFish » Tue Sep 08, 2015 7:27 pm
RossDagley wrote:Part number is 4F0615301L
They aint small...
F in hell that disc and pad look flipping huge!
RossDagley
Re: RS6 390mm Discs
Post by RossDagley » Tue Sep 08, 2015 7:44 pm
I have big hands too. So I'm told ;)
Previously:
RossDagley
Re: RS6 390mm Discs
Post by RossDagley » Tue Sep 08, 2015 7:52 pm
nutter69 wrote:Yea dude i know the implications I'm a race technician by trade so know what is required for a performance based improvement..
anyone use these?
What improvement over standard are you hoping for with larger discs? Standard discs don't fade with decent pads and fluid. I stand by my statement that moment of inertia outweighs any gains you may see.
Previously:
Users browsing this forum: No registered users and 190 guests
