RS6 390mm Discs
RS6 390mm Discs
anyone got the part numbers handy?
Re: RS6 390mm Discs
cant make it out, i can go look inthe garage tomorrow
they dont really fit tho is it for the b7?
Re: RS6 390mm Discs
yea...
going to make a bracket for the calliper so its spaced right... it fits the hub I'm guessing the calliper is in the wrong position
Re: RS6 390mm Discs
nutter69 wrote:yea...
with a 4mm 0r 5mm spacer behind the disk on the hub it will fit or grind away the nub on the suspension leg,
you will get alot of inside disk that isnt on contact with the pad tho
Re: RS6 390mm Discs
The pad sweep on that is gunna be <beep>!
buy a set of C6 callipers to go with them.
- RossDagley
- Top Gear
Re: RS6 390mm Discs
Part number is 4F0615301L
They aint small...
The additional unsprung weight and moment of inertia costs will be crippling. Bad idea.
They aint small...
Previously:
Previously:
Re: RS6 390mm Discs
This.RossDagley wrote: The additional unsprung weight and moment of inertia costs will be crippling. Bad idea.
But are we talking performance here or "looks"? Plenty of people going for 20 inch wheels too even though it makes pretty much everything worse.
The RS4 brake disc size is fine. The calipers are fine, too. If you want to improve braking performance you need:
- Proper brake pads (not EBC, be prepared to spend some money)
- Brake discs with proper cooling vanes in them. The stock discs don't have any.
That's what I will do when I start tracking the car. For road use, just using decent pads will go a long way. If we're talking aesthetics then that's a different matter.
B7 RS4 saloon Misano red, comfy seats, JHM tune & JHM full exhaust with cats and resonators - gone.
C5 RS6 Avant Daytona/Cognac - gone.
981 Cayman GTS Gray/Orange.
My youtube
My youtube
Re: RS6 390mm Discs
Yea dude i know the implications I'm a race technician by trade so know what is required for a performance based improvement..
i have seen a company called giro disc.. they do 380mm discs and you get the spacers too required to space the calliper out..
anyone use these?
anyone use these?
Re: RS6 390mm Discs
F in hell that disc and pad look flipping huge!RossDagley wrote:Part number is 4F0615301L
They aint small...
- RossDagley
- Top Gear
Re: RS6 390mm Discs
I have big hands too. So I'm told
Previously:
Previously:
- RossDagley
- Top Gear
Re: RS6 390mm Discs
What improvement over standard are you hoping for with larger discs? Standard discs don't fade with decent pads and fluid. I stand by my statement that moment of inertia outweighs any gains you may see.nutter69 wrote:Yea dude i know the implications I'm a race technician by trade so know what is required for a performance based improvement..
anyone use these?
Previously:
Previously:
Users browsing this forum: Majestic-12 [Bot] and 150 guests
