Headlight adjustment for driving 'en France'
mustdash
Post by mustdash » Tue Apr 21, 2015 11:02 am
This is probably a stupid question but hey ho, I'll ask anyway.....
Does the RS4 have adjustable headlights for driving abroad, or do I need a set of stick on things from Halfords?
CURRENT: Montecarlo Blue Alfa Romeo Giulia Quadrifolglio, 2.9ltr bi-turbo, 510bhp
PREVIOUS: Volvo V60 Polestar, build number 149/700 worldwide - 3ltr straight 6 turbo. 350bhp remapped to 400bhp. Only one of 120 in the UK
PREVIOUS: Misano red B7 saloon, stage 2 map to 425bhp, manifold flap delete, KW V3 coilovers.
Re: Headlight adjustment for driving 'en France'
Post by MikeFish » Tue Apr 21, 2015 11:08 am
I think you can adjust the angle using VCDS if you have adaptive headlights.
Not sure what you do if you don't have adaptives though.
toyneg
Post by toyneg » Tue Apr 21, 2015 11:08 am
mustdash wrote:This is probably a stupid question but hey ho, I'll ask anyway.....
you can change the headlights for Europe using Vagcomm but it isnt something i have bothered with - or the stickers for that matter haha
jonicox
Post by jonicox » Tue Apr 21, 2015 12:02 pm
Your option in VCDS will be for tourist mode, but like toyneg, I haven't bothered with either this setting or Stickers.
8L S3 with stage 2 (gone)
B7 A4 DTM (gone)
B7 RS4 (Miltek Res Valved, 100 cell cats, Ceramics, Carbon cleaned) gone
C7 RS6 Panther, carbon pack,
mustdash
Post by mustdash » Tue Apr 21, 2015 2:16 pm
What are 'Le Plod' likely to do should I not bother (bear in mind I'm going to Le Mans so is likely to be a higher police presence).... I don't fancy being required to drain my bank account under the watchful eye of the Gendarmes....
GlenRS
Post by GlenRS » Tue Apr 21, 2015 2:27 pm
Yes you can adjust them with VCDS.
Here is the thread from when I asked about it
viewtopic.php?f=35&t=99198&p=548037#p548037
toyneg
Post by toyneg » Tue Apr 21, 2015 4:46 pm
mustdash wrote:What are 'Le Plod' likely to do should I not bother (bear in mind I'm going to Le Mans so is likely to be a higher police presence).... I don't fancy being required to drain my bank account under the watchful eye of the Gendarmes....
i guess they could or would fine you but i have driven a few times over there and havent ever had any issue and i will be in France this Friday and wont bother as when i get back Monday night they would then be wrong for the UK haha
PetrolDave
Post by PetrolDave » Tue Apr 21, 2015 5:46 pm
I have adaptive headlights and simply set them into Tourist Mode using VCDS while we're on the train in "The Tunnel".
neilparf
Post by neilparf » Tue Apr 21, 2015 7:34 pm
PetrolDave wrote:I have adaptive headlights and simply set them into Tourist Mode using VCDS while we're on the train in "The Tunnel".
Done this several times - it's simply brilliant and easy.
Gone but never forgotten:
mustdash
Post by mustdash » Tue Apr 21, 2015 9:25 pm
Unfortunately I don't own a Vagcom...... So I will risk not having any!
Trups
Trader (Expired)
Post by Trups » Tue Apr 21, 2015 10:25 pm
You got non adaptives?
mustdash
Post by mustdash » Wed Apr 22, 2015 7:45 am
Trups wrote:You got non adaptives?
No - I've got the adaptive 'bend when you turn the steering wheel' lights....
Trups
Trader (Expired)
Post by Trups » Wed Apr 22, 2015 9:00 am
Then it's a VCDS job. Non adaptives have a switch inside to change the pattern
alefustec
Post by alefustec » Wed Apr 22, 2015 9:28 am
Trups wrote:Then it's a vcds job. Non adaptives have a switch inside to change the pattern
I'm off to France Friday too, and wasn't going to bother with the stickers, I'm non adaptive lights so would love to k ow where the switch is located if it's easy to do?
06 Phantom Black RS4 Saloon(since Jan 15)
19x9.5 Bola alloys, LED interior/door lights, exhaust flap delete, pre-cat delete, resonator delete, chrome to black optics, B&C pillars, rear boot strip, front grills & lower intakes gloss black, revolution induction kit, LED Drl's, de-tangoed, RNSE delete - Pioneer Apple CarPlay, reverse camera. 380mm upgraded JHM front rotors, Eibach control arms, Bilstein P14's, MCarbon diffuser & Cupra R splitter.
toyneg
Post by toyneg » Wed Apr 22, 2015 9:30 am
what time are you leaving for France Friday mate? Channel Tunnel?
