Headlight adjustment for driving 'en France'
This is probably a stupid question but hey ho, I'll ask anyway.....
Does the RS4 have adjustable headlights for driving abroad, or do I need a set of stick on things from Halfords?
CURRENT: Montecarlo Blue Alfa Romeo Giulia Quadrifolglio, 2.9ltr bi-turbo, 510bhp
PREVIOUS: Volvo V60 Polestar, build number 149/700 worldwide - 3ltr straight 6 turbo. 350bhp remapped to 400bhp. Only one of 120 in the UK
PREVIOUS: Misano red B7 saloon, stage 2 map to 425bhp, manifold flap delete, KW V3 coilovers.
Re: Headlight adjustment for driving 'en France'
I think you can adjust the angle using VCDS if you have adaptive headlights.
Not sure what you do if you don't have adaptives though.
you can change the headlights for Europe using Vagcomm but it isnt something i have bothered with - or the stickers for that matter hahamustdash wrote:This is probably a stupid question but hey ho, I'll ask anyway.....
Your option in VCDS will be for tourist mode, but like toyneg, I haven't bothered with either this setting or Stickers.
8L S3 with stage 2 (gone)
B7 A4 DTM (gone)
B7 RS4 (Miltek Res Valved, 100 cell cats, Ceramics, Carbon cleaned) gone
C7 RS6 Panther, carbon pack,
B7 A4 DTM (gone)
What are 'Le Plod' likely to do should I not bother (bear in mind I'm going to Le Mans so is likely to be a higher police presence).... I don't fancy being required to drain my bank account under the watchful eye of the Gendarmes....
Yes you can adjust them with VCDS.
Here is the thread from when I asked about it
viewtopic.php?f=35&t=99198&p=548037#p548037
i guess they could or would fine you but i have driven a few times over there and havent ever had any issue and i will be in France this Friday and wont bother as when i get back Monday night they would then be wrong for the UK hahamustdash wrote:What are 'Le Plod' likely to do should I not bother (bear in mind I'm going to Le Mans so is likely to be a higher police presence).... I don't fancy being required to drain my bank account under the watchful eye of the Gendarmes....
- PetrolDave
I have adaptive headlights and simply set them into Tourist Mode using VCDS while we're on the train in "The Tunnel".
Done this several times - it's simply brilliant and easy.PetrolDave wrote:I have adaptive headlights and simply set them into Tourist Mode using VCDS while we're on the train in "The Tunnel".
Gone but never forgotten:
Unfortunately I don't own a Vagcom...... So I will risk not having any!
You got non adaptives?
No - I've got the adaptive 'bend when you turn the steering wheel' lights....Trups wrote:You got non adaptives?
Then it's a VCDS job. Non adaptives have a switch inside to change the pattern
I'm off to France Friday too, and wasn't going to bother with the stickers, I'm non adaptive lights so would love to k ow where the switch is located if it's easy to do?Trups wrote:Then it's a vcds job. Non adaptives have a switch inside to change the pattern
06 Phantom Black RS4 Saloon(since Jan 15)
19x9.5 Bola alloys, LED interior/door lights, exhaust flap delete, pre-cat delete, resonator delete, chrome to black optics, B&C pillars, rear boot strip, front grills & lower intakes gloss black, revolution induction kit, LED Drl's, de-tangoed, RNSE delete - Pioneer Apple CarPlay, reverse camera. 380mm upgraded JHM front rotors, Eibach control arms, Bilstein P14's, MCarbon diffuser & Cupra R splitter.
what time are you leaving for France Friday mate? Channel Tunnel?alefustec wrote:I'm off to France Friday too, and wasn't going to bother with the stickers, I'm non adaptive lights so would love to k ow where the switch is located if it's easy to do?Trups wrote:Then it's a vcds job. Non adaptives have a switch inside to change the pattern
Users browsing this forum: No registered users and 1574 guests
