Headlight Washer Stuck
Stairs
Post by Stairs » Fri Feb 13, 2015 8:37 pm
My driver side headlight washer comes out but never retracts all the way back in, sometimes stays out all the way, sometimes pokes out a little, any easy solutions to this that anyone knows of??
RossDagley
Re: Headlight Washer Stuck
Post by RossDagley » Sun Feb 15, 2015 10:32 am
No, but my friends S3 does this so I'm subscribing to the thread for when you get replies. Sorry I can't help!
Previously:
iluvmercs
Post by iluvmercs » Thu Feb 19, 2015 9:18 pm
My car does this occasionally, but only during very cold weather.
This may sound daft, but could it be sticky because of the weather?
Darren
JJJ
Post by JJJ » Thu Jan 07, 2016 3:09 pm
Didn't want to create a new topic for this, I have the same problem...
Some people say you pull the washer as far out as you can and then wiggle it. Springs and pins should then fall back in their right place.
Did this and it didn't work for me, can anybody tell me how I could possibly fix this?
Covkiller
Post by Covkiller » Thu Jan 07, 2016 10:40 pm
Both of mine have stopped working, I think it must be an electrical problem. Must get round to sorting it out.
JJJ
Post by JJJ » Fri Jan 08, 2016 9:13 am
Did you check the fuse?
rwilsonrs4
Post by rwilsonrs4 » Fri Jan 08, 2016 11:39 pm
dont think there is electrics involved unless its tied into the lighting circuit somewhere so might be a fuse but the function itself is due to the high vol pump which pushes the piston out and then sprays from the jets, then the spring retracts it when pressure is off so if you hear the pump run it might be just stuck or the pipe is off ,
1/4 mile 12.01 secs 123.5mph
Users browsing this forum: No registered users and 75 guests
