Door latch issue
3.0 V6 24v TFSI - 329 bhp
coullstar
Door latch issue
Post by coullstar » Tue Dec 16, 2014 10:09 am
My rear drivers door is not unlocking from the outside, inside handle works fine. It seems to work okay after this but if I then lock the car and unlock it again doesn't work.
anybody had this issue and had it fixed? Don't mind tackling it myself if its easy enough but if part are expensive then I'll try a warranty claim.
B5 RS4
99 - Carerra 2
05 - T5 shuttle daily.
robokn
Re: Door latch issue
Post by robokn » Thu Dec 18, 2014 9:46 am
IS a common problem on MK II TT's mine does it pain in the arse, Not sure anyone has a solution yet
P300
Post by P300 » Thu Dec 18, 2014 4:54 pm
Mine did something similar. Apparently it's the solenoid that is failing. Not a big deal to fix so you could probably do it yourself - the guy who did mine said he had seen this problem before.
Skiptowncat
Post by Skiptowncat » Wed Feb 04, 2015 5:31 pm
I have the same issue, I just can't be bothered taking the door card out in this cold weather.
