My rear drivers door is not unlocking from the outside, inside handle works fine. It seems to work okay after this but if I then lock the car and unlock it again doesn't work.
anybody had this issue and had it fixed? Don't mind tackling it myself if its easy enough but if part are expensive then I'll try a warranty claim.
Door latch issue
Door latch issue
B5 RS4
99 - Carerra 2
05 - T5 shuttle daily.
99 - Carerra 2
Re: Door latch issue
IS a common problem on MK II TT's mine does it pain in the arse, Not sure anyone has a solution yet
Mine did something similar. Apparently it's the solenoid that is failing. Not a big deal to fix so you could probably do it yourself - the guy who did mine said he had seen this problem before.
Skiptowncat
- 1st Gear
I have the same issue, I just can't be bothered taking the door card out in this cold weather.
Users browsing this forum: No registered users and 44 guests
