Tyre pressure valves
ashy
Post by ashy » Mon Jun 30, 2014 6:41 pm
Hi guys
Is it possible to remove the valves and then refit them?
I want to get my wheels powder coated so wondered if you can reuse valves.
Audi Pardner
Re: Tyre pressure valves
Post by Audi Pardner » Mon Jun 30, 2014 7:05 pm
Assume you're talking about the TPMS?
When I had my rims refurbed the guys removed and refitted the valves with no problems and the TPMS worked fine afterwards.
rwilsonrs4
Post by rwilsonrs4 » Mon Jun 30, 2014 7:11 pm
totally depends on condition of the stems , i had both sets of mine done and i think 3 out of the 8 had to be replaced as the threads came off as the nut is being removed so ...i would get a couple spare in case , the TPMS bit is separate and is bolted on to the valve so not that expensive , a tenner each i think they were , remember to reset the TPMS in the DIS as you may well get them mixed up and the new pressure settings on reassembly be different as well
1/4 mile 12.01 secs 123.5mph
flying_tomatoes
Post by flying_tomatoes » Mon Jun 30, 2014 7:42 pm
just check the rubber and make sure that portion is in good condition, if it is go ahead and reuse them
2007 RS4 - Bagged and Blown. IG: @Flying_Tomatoes
DaytonaRs4
Post by DaytonaRs4 » Mon Jun 30, 2014 8:05 pm
I bought a few valve service kits from tps when i got my wheels refurbed iirc they were around £7 each kit
2013 RS5 Phantom Black, MRC Stage 2 and TCU, Bilstein B16 IRC, 034 Arms, H&R ARB's, Milltek non res, ITG, 20” Ispiri FFR6 / PS4s, AP Radical 6 pot brakes / 390mm floaters, Pagid RSL1, JL Audio, EMtuning headlight build, Gtechniq ceramic and Llumar PPF
Gone: Daytona B7 RS4 saloon
Sonnyjim
Post by Sonnyjim » Mon Jun 30, 2014 9:04 pm
£7? When I bought my car the previous owner had bought 3, (yes, for some reason 3) new ones from audi and I'm sure they were £30 a pop. I'll look out the receipt just to check.
Sonnyjim
coupe_bloke
Post by coupe_bloke » Mon Jun 30, 2014 9:12 pm
Hi guys
I had my rear tyres changed recently. The TPMS sensors are apparently no longer working, and also the thread on at least one wheel is a little worn... this makes getting a sensible reading at the service station very difficult as the airgun won't fit over the stem properly... it's more often the case that more air comes out than goes in! I'm not bothered about keeping the TPMS system - I prefer to check my tyres regularly anyway.
Basically I think I need some new stems or valves, anyone know what my options are here, eg:
1) Can buy stems seperately from TPMS?
2) Have to buy TPMS as part of whole fitting?
Some idea of costs would be much appreciated too.
Many thanks
WillRS
Post by WillRS » Mon Jun 30, 2014 9:32 pm
you can buy the stems on their own. not at all expensive - £8 a valve stem i think ? have a look on stoke audi parts website - I bought some from them previously
or if you look back on a previous post on here there is a chap in Poland selling sensors AND stems for a pretty decent price on ebay if you want to change the whole lot in one go.
ashy
Post by ashy » Mon Jun 30, 2014 9:56 pm
Thanks for replys guys, i will take the tyres off and see what the condition of the valves are and go from there then. :beerchug:
coupe_bloke
Post by coupe_bloke » Tue Jul 01, 2014 9:20 pm
Thanks for replying to my thread hijack too! Is it this...?
http://www.stokeaudi-parts.co.uk/produc ... 01361.html
WillRS
Post by WillRS » Tue Jul 01, 2014 9:26 pm
yes think those are the ones - check with the parts people just to make sure but 99% certain thats the ones
The_Coat
Post by The_Coat » Tue Jul 01, 2014 9:28 pm
RS4 Avant - Misano Red
Users browsing this forum: No registered users and 327 guests
