Tyre pressure valves
Hi guys
Is it possible to remove the valves and then refit them?
I want to get my wheels powder coated so wondered if you can reuse valves.
Audi Pardner
Re: Tyre pressure valves
Assume you're talking about the TPMS?
When I had my rims refurbed the guys removed and refitted the valves with no problems and the TPMS worked fine afterwards.
Misano Red B7 RS4 Avant. 20" Rotors. KW adjustable spring kit. 8 & 10mm H&R spacers. MRC Stage 2 remap. Pre-cat delete & x-pipe.
rwilsonrs4
totally depends on condition of the stems , i had both sets of mine done and i think 3 out of the 8 had to be replaced as the threads came off as the nut is being removed so ...i would get a couple spare in case , the TPMS bit is separate and is bolted on to the valve so not that expensive , a tenner each i think they were , remember to reset the TPMS in the DIS as you may well get them mixed up and the new pressure settings on reassembly be different as well
1/4 mile 12.01 secs 123.5mph
- flying_tomatoes
just check the rubber and make sure that portion is in good condition, if it is go ahead and reuse them
2007 RS4 - Bagged and Blown. IG: @Flying_Tomatoes
- DaytonaRs4
I bought a few valve service kits from tps when i got my wheels refurbed iirc they were around £7 each kit
2013 RS5 Phantom Black, MRC Stage 2 and TCU, Bilstein B16 IRC, 034 Arms, H&R ARB's, Milltek non res, ITG, 20” Ispiri FFR6 / PS4s, AP Radical 6 pot brakes / 390mm floaters, Pagid RSL1, JL Audio, EMtuning headlight build, Gtechniq ceramic and Llumar PPF
Gone: Daytona B7 RS4 saloon
£7? When I bought my car the previous owner had bought 3, (yes, for some reason 3) new ones from audi and I'm sure they were £30 a pop. I'll look out the receipt just to check.
Sonnyjim
Sonnyjim
coupe_bloke
Hi guys
I had my rear tyres changed recently. The TPMS sensors are apparently no longer working, and also the thread on at least one wheel is a little worn... this makes getting a sensible reading at the service station very difficult as the airgun won't fit over the stem properly... it's more often the case that more air comes out than goes in! I'm not bothered about keeping the TPMS system - I prefer to check my tyres regularly anyway.
Basically I think I need some new stems or valves, anyone know what my options are here, eg:
1) Can buy stems seperately from TPMS?
2) Have to buy TPMS as part of whole fitting?
Some idea of costs would be much appreciated too.
Many thanks
Many thanks
you can buy the stems on their own. not at all expensive - £8 a valve stem i think ? have a look on stoke audi parts website - I bought some from them previously
or if you look back on a previous post on here there is a chap in Poland selling sensors AND stems for a pretty decent price on ebay if you want to change the whole lot in one go.
Thanks for replys guys, i will take the tyres off and see what the condition of the valves are and go from there then.
coupe_bloke
Thanks for replying to my thread hijack too! Is it this...?
http://www.stokeaudi-parts.co.uk/produc ... 01361.html
yes think those are the ones - check with the parts people just to make sure but 99% certain thats the ones
This is the eBay chap:
http://www.ebay.co.uk/itm/371091180827
RS4 Avant - Misano Red
Users browsing this forum: Google [Bot] and 333 guests
