Carbon Cleaning RS4
Carbon Cleaning RS4
Hi Guys
Just recently bought another 56 plate Audi RS4 (I have 2 in the same year) its not as smooth as my other and i don't get that little pull in high revs, got an audi guy to take off the manifold and as i suspected the valves are caked in carbon (Really bad) - my problem is finding someone to take this job on, I'm in between Edinburgh and Glasgow, got the money just need the right guy to do it.
Anyone close by this way to do this ? i was gonna try terra clean but i don't think it will get this off the valves.
- Firestarter
Re: Carbon Cleaning RS4
Have a drive down to Unit20....Im sure that they could do this while you wait....Worth the journey as they are top boys.....Unsure of any others apart from MRC & AmD down here in the south
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Thanks for your reply - where about exactly is this Unit20 mate ?
Revolution have done a few too.
I take it you guys are referring to terra clean - I'm looking for someone to actually take the cylinder head off and clean it.
I am referring to a clean by hand, AMD charge £500.00 not sure what Unit 20 or Revolution charge but they both do the carbon clean by the same process.
Ok thanks - do they just take the manifold off or do they actually take the cylinder head out ? just curious as 500 seems to be quite cheap for that.
manifold as this exposes the bits they need to clean
Spaceman_RS4
There's a garage done a few near by bud autohaus I think it's guys on here that had it done yanos I think pm him matey save you a trip
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
Guys - thanks for the recommendations, i gave autohaus a call and will find out tomorrow when we can get it booked in, my problem is exactly as "yanos" had spaceman thanks, flat around 5 to 6k revs EPC light on and off.
Again thanks.
Again thanks.
Spaceman_RS4
A might get mine done in the spring ave got a good kick tho and no epc lights
Have a look at the AIrbox flap vac solenoid (located under the air box) common fault it splits and causes a massive vac leak) - you can do a simple test.
The vac pipe has a joining piece on the o/s of the main rad tucked under the front slam panel.
Knock off the EPC light and clear any faults pull the pipes apart at the joining piece and plug the engine side - take her for a spin - there'll be no kick because you have isolated that side of things but just see if the EPC light shows
If its doesn't the air flap solenoid needs replacing (big vac leak and maybe notice ex flaps rattling)
I posted pics of solenoid and replacement in a thread somewhere
- edit - here we go
http://forum.rs246.com/viewtopic.php?f=39&t=99232
Only takes 5 mins and a 20 min test drive to check it
Also check all the vac pipes near the manifold mechanisms are free not chaffing or pinching on the actuator arms
- edit - here we go
Gone but not forgotten boohoo !!!
RS4 Sprint Blue Avant on Dyno after Carbon Clean http://youtu.be/7lsBbmmaDQc
+1ROY wrote:Have a look at the AIrbox flap vac solenoid (located under the air box) common fault it splits and causes a massive vac leak) - you can do a simple test.
I posted pics of solenoid and replacement in a thread somewhere - edit - here we go http://forum.rs246.com/viewtopic.php?f=39&t=99232
Only takes 5 mins and a 20 min test drive to check it![]()
I was going to say it sounds like you have other issues not just a coked up engine. There's no doubt your engine will be all coked up but I bet your other RS4 that runs better looks no better with the manifold off (unless it has very recently been cleaned).
Mines still pulls pretty good but i don't get no kick at the top end as i do in my other RS4 plus it just feels as if its working harder to get there - actually at times in 1st or 2nd gear if i put the foot down at times i got a right flat spot enough to kinda throw you forward a bit but the carbon has to play a good part in it as its totally caked around those valves.Spaceman_RS4 wrote:A might get mine done in the spring ave got a good kick tho and no epc lights
Thanks for that, I'm gonna check this tomorrow while i have some time to burn, thanksROY wrote:Have a look at the AIrbox flap vac solenoid (located under the air box) common fault it splits and causes a massive vac leak) - you can do a simple test.
Yes i suspect its got a leak somewhere due to the sudden loss of power occasionally at high revs, back to low revs its fine, i will do as mentioned above tomorrow though, either way i will get the guys at autohaus to check it all over when he's cleaning it out.MikeFish wrote:+1
The other RS just seems to get up there with little effort, never seen how the valves are on this one but it does have 20K less miles on it.
Users browsing this forum: No registered users and 748 guests
