**SOLD**B7 RS4 Sprint Blue, quilted leather & carbon buckets
Teutonic Tuner
Post by Teutonic Tuner » Sat Feb 16, 2013 8:44 pm
So following on from my 'what's it worth' thread http://forum.rs246.com/viewtopic.php?f=35&t=102235 I have decided to put my pristine B7 RS4 up for sale purely on the basis that it just isn’t getting used like it should be. Cars like these deserve to be driven regularly and it’s just a waste for it to be sat on the drive to only get its legs stretched for a few short trips over the weekend.
So heres' the details:
Sprint Blue saloon
Offers around £SOLD
Date of registration 16-02-2006 (cheaper road tax band, £260 per year)
Current mileage 39701
Full Audi service history, last service carried out just before Christmas.
Taxed until end of June
MOT until 21st June
The alloys were refurbed at Lepsons before I bought the car but the front left alloy has some kirbing now and there are a couple of minor marks on 2 of the other alloys. Tyres are Michelin Pilot Super Sports with a good 5-6mm of tread all round.
Bodywork is in near perfect condition with the usual amount of stone chips and a couple of minor scratches to the front bumper but there are no dents/trolley marks to the bodywork etc.
There are no problems with the DRC suspension with no leaks. 2 dampers and a valve were replaced 27-03-2008 and pressures checked at Camberley Audi 26-02-2011 and pressure were bang in the middle of the acceptable range.
I always like to do something a little different with my cars and I decided to add a genuine Audi DTM carbon front splitter, fit a JHM short shifter from the US and took the plunge to have the front seats re-trimmed with new matching Valcona Leather Black Metallic (sourced from Germany) with quilted details and at the same time I skinned the backs of the buckets and the seat-belt loops with genuine 2x2 twill 650grams/sqm carbon fibre (matches the OEM carbon interior inlays) finished at my local bodyshop with a clear UV lacquer to give a perfect finish. It should be noted that the carbon on the back of the passenger seat is absolutely perfect but the carbon on the back of the driver’s seat isn’t as perfect as I would have liked. The reason for this is that I tried a different resin which ended up having the clarity of the other seat and is very slightly cloudy in patches, I am being a little picky here and most people wouldn’t notice this but being a bit of a perfectionist I thought I should point this out. It doesn’t show up in photos as glossy carbon fibre is very difficult to photograph. This doesn’t detract from what is a very cool interior mod and I have had lots of people comment on how good the carbon looks.
Interior is in near perfect condition. The seats pre-retrim were excellent and only showed minor wear to the driver’s seat bolster.
Apart from the carbon splitter, interior mods, JHM Short shifter (which is well worth fitting), the car is absolutely standard. I have disconnected the exhaust valves so they are open all the time which gives a much better sound all of the time instead of just when at higher rpms when the sport button is pressed. This can be returned to standard if required.
You can check out my thread here:
http://forum.rs246.com/viewtopic.php?f=35&t=96092
Options fitted (codes from chassis sticker):
7A2 = CD changer
5MN = Carbon Fibre Decorative inserts
7X2 = Park distance control, front and rear
3NZ = Rear seat bench unsplit, backrest split folding
8EC = Bi-functional headlight with gas discharge lamp, for driving on the left
8Q5 = Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1)
9Q4 = Multi-function display/on-board computerwith check control
7Q2 = Navigation system with color screen (RNS-E)
Q4P = Sports front seats (Buckets), heated with electric lumber adjustment
4GT = Heat-insulating glass windshield
2PX = Leather trimmed sports steering wheel (flat bottom)
Service booklet, owners manuals and leather wallet, V5 and keys all present.
History (I have original invoices for all these and more):
16-02-2006 00010m Epsom Audi - PDI & Road test
27-03-2008 10060m Epsom Audi - Suspension knocking - osf & osr dampers & valve replaced, steering knocking - new rack bolts fitted
25-06-2009 11468m Camberley Audi MOT
22-02-2010 13489m Epson Audi - £623.28 - Variable Service - Brake Fluid, new drivers door handle, new wheel bolt, New Pollen filter
10-04-2010 Elite Auto Works - new front brake discs & tyre sealant
23-07-2010 18442m Camberley Audi MOT
26-02-2011 26185m Camberley Audi - £697.82 - Variable Service - Air filter, Pollen filter, new spark plugs, new fuel filter. Comments: No knocks or leaks from from DRC, n/s pressure 13.25bar, o/s pressure 13.50bar, all ok. Corrosion to oil cooler pipes but no leaks.
22-06-2011 31888m Camberley Audi MOT
02-03-2012 Lepsons wheel refurb £456 & KDS wheel sealant £96
28-05-2012 37174m Western Audi MOT - Advisery - windscreen chip (there are a couple of chips to windscreen but are not serious and are not MOT failures)
30-08-2012 38008m CLCM suspension geometry check
01-09-2012 38015m Gearbox and rear differential oil change, see my thread which is now a sticky in the FAQ section http://forum.rs246.com/viewtopic.php?t=98880
24-12-2012 39531m Edinburgh Audi full service
Interior
Gear knob detail:
JHM Short shifter fitted:
Last edited by Teutonic Tuner on Sat Apr 13, 2013 3:52 pm, edited 3 times in total.
Sprint Blue B7 RS4 gone but not forgotten...
Teutonic Tuner
Re: FS: B7 RS4 Sprint Blue, quilted leather & carbon buckets
Post by Teutonic Tuner » Sun Feb 17, 2013 11:02 pm
I've added MOT & tax expiry dates for clarification.
jaysrs4
Post by jaysrs4 » Mon Feb 18, 2013 9:56 pm
PM'd
Teutonic Tuner
Post by Teutonic Tuner » Tue Feb 19, 2013 2:35 pm
Replied...
sync24
Post by sync24 » Wed Feb 20, 2013 12:17 am
Where did you get that OEM DTM Splitter mate - I've seen a couple on ebay?? - but would like to source a decent one - I do like the way it sets the front of the car off....
Post by MikeFish » Wed Feb 20, 2013 7:47 am
You want a decent one try the stealers. They will pull your pants down though.
Teutonic Tuner
Post by Teutonic Tuner » Wed Feb 20, 2013 12:21 pm
Theres one on ebay at the moment, bids upto £310+delivery! I got mine from a dealer on ebay but they have sold them all by the looks of it.
brn7y
Post by brn7y » Wed Feb 20, 2013 2:10 pm
There is a used one on eBay, but don't bother bidding as I saw it first and have dibs to bid against the general public.
HD
Teutonic Tuner
Post by Teutonic Tuner » Sat Apr 13, 2013 3:50 pm
Sold to forum member Nainoo. Hope you enjoy the drive home mate, it was nice (but complicated!!) doing business with ya.
Hope you don't pimp it up too much, it's perfect the way it is!
Enjoy
TT
Nainoo
Re: **SOLD**B7 RS4 Sprint Blue, quilted leather & carbon buc
Post by Nainoo » Mon Apr 15, 2013 5:14 pm
Cheers for your Patience on Saturday!!
I did enjoy my drive down :nogarors4: ... don't worry decided to keep it as it is like you said "it's perfect the way it is!"
Good luck with the next purchase, I would like to see what kind of small mods you put on it like the RS4.
Nainoo
Sprint Blue known as Blueberry Beast
Users browsing this forum: No registered users and 547 guests
