B7 RS4 gearbox & rear diff oil change guide
Teutonic Tuner
Post by Teutonic Tuner » Sat Sep 01, 2012 12:21 pm
Following on from this thread http://forum.rs246.com/viewtopic.php?f=35&t=98654 where I queried the specs for the gearbox and diff oils I have completed the oil changes and as promised have put together a little DIY to help anyone else that wants to do the same.
Oil specs are as follows:
Gearbox:
Audi OE part No: G052911A SAE 75 W 90 (1 litre, synthetic Oil)
oil spec: 75W90 GL4+ (suitable for synchromesh transmissions and hypoid gears)
capacity: 3.2 litre (fill to -2 mm +/-1 mm)
torque plug to ~30 lb/ft
Rear differential:
Audi OE part No: G052145A1 (0.5 litre), G052145S2 (1.0 litre)
oil spec: 75W90 GL5 (suitable for hypoid gears)
capacity: 0.9 litre (fill to lip/overflow)
torque plug to ~33 lb/ft
Both oils must be fully synthetic.
Opie oils recommended Gulf Competition 75w-90 (Ester based fully synthetic) as an alternative oil to the OE Audi oils that is suitable for both the gearbox and diff so I purchased a 5 litre tub for £52 which was a very good deal http://www.opieoils.co.uk/p-60162-gulf- ... 5w-90.aspx
First of all get the car off the ground using these:
The car must be level for draining to make sure you get as much oil out as possible and for filling to make sure the correct amount is added. I raised the rear of the car first using the diff casing as the central jack point, then the front using the point on the sub-frame where the gearbox mount attaches (see pic 4).
Tools required, including 10mm hex bit for all 4 plugs, torque wrench, extension bar and a hand pump with container (old 1 litre carton used here, cleaned-out):
Front jack point circled, gearbox drain plug (green arrow) & fill plug (red arrow)
It's always good practice when draining/filling diffs etc to loosen the fill plug first as you don't want to drain the oil to find that the fill plug is ceased. This is where the extension bar is needed.
Another pic showing the extension bar and ratchet used to remove the fill plug:
Then remove drain plug and drain oil, I used an old 5 litre screenwash carton with the top cut away, works better than a shallow drain pan as it catches more of the splashes:
I drained 3 litres from the gearbox, the oil looks fairly dirty dark brown so is well worth changing even though my RS4 has only done 38k miles.
After re-fitting the drain plug (there are no copper washers to replace) hook the hose from the fill pump into the fill hole
I removed the front left wheel to get better access to the pump as you will get a dead arm after pumping just 1/2 litre whilst lay under the car...I promise you!
From the front left wheel arch you will also be able to see the fill hole so you can keep an eye on the level, this is to be filled to just below the fill hole so keep checking with your finger.
Tools for the diff (+torque wrench), note only mid length extension bar is required for the fill plug.
Drain plug (green arrow), fill plug (red arrow)
I drained about 0.8 litre from the diff
and again looked a pretty dirty dark brown
Then fill in the same manner as the gearbox but this time fill until oil starts to overflow from the fill hole (no more than 0.9 litres or similar to what you drained out as over filling diffs can cause the oil to blow past the diff seals).
I spent a couple of hours doing this but I was taking photos and going at a fairly leisurely pace. It’s quite a satisfying job and would say the gear changes feel smoother, but my gearbox was pretty smooth anyway so those with stiffer gearboxes may find more of an improvement.
Last edited by Teutonic Tuner on Fri Dec 11, 2015 11:19 am, edited 2 times in total.
Sprint Blue B7 RS4 gone but not forgotten...
Spaceman_RS4
Re: B7 RS4 gearbox & rear diff oil change guide
Post by Spaceman_RS4 » Sat Sep 01, 2012 6:55 pm
Cracking write up bud. I think I might do this, luckily I have a 2 poster so saves some time.
Cheers for the links to the opie stuff to.
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
Teutonic Tuner
Post by Teutonic Tuner » Sat Sep 01, 2012 7:43 pm
awe the stuff of dreams...your very own car lift! :bowdown:
We've just got a new house purchase going through at the moment that has the all-important garage, needs making bigger but either a lift or pit will be going in!
Spaceman_RS4
Post by Spaceman_RS4 » Sun Sep 02, 2012 1:09 am
well note mine yet got garage at my house the rs fits in ok.
my dad retired and built a 3-4 car garage with a 4 ton 2 post lift (How lucky am I?) that goes full height I'm 6ft 3 and can walk under the disco 3 when its up.
got full use 24/7 when i want and in bout 7 years i should be buying the house from him as he gets a place in spain or that and buys my wee bungalow off me..
Teutonic Tuner
Post by Teutonic Tuner » Sun Sep 02, 2012 4:46 pm
reckon with a lift you should get this done in about 1/2hr!
ROY
Post by ROY » Sun Sep 02, 2012 9:35 pm
Great wright up mate
A couple of jobs which i need to do :beerchug:
Could do with this adding to a sticky section to help others :thumbs:
Gone but not forgotten boohoo !!!
RS4 Sprint Blue Avant on Dyno after Carbon Clean http://youtu.be/7lsBbmmaDQc
TonyHayers
Post by TonyHayers » Mon Sep 03, 2012 11:58 am
Thanks for this TT, a really detailed walkthrough, much appreciated.
06 Phantom Black Saloon:
^ GONE :cry:
ArthurPE
Post by ArthurPE » Mon Sep 03, 2012 2:35 pm
great write up
especially like the fact that you measured the drained quantities
otterolly
Post by otterolly » Tue Mar 12, 2013 2:04 pm
nice write up with good information.....thanks
Surrey Sam
Post by Surrey Sam » Tue Mar 12, 2013 3:08 pm
A great write up, many thanks for taking the time to detail and share it.
I have found on previous cars that getting the oil warm first, helps with draining the oil out and you can get a little more volume removed. You just have to be careful with the oil being hot and burning you.
**I've reported to Moderator this topic so as to get added to the FAQ post at the top of the page**
cherub72
Post by cherub72 » Tue Mar 12, 2013 3:52 pm
Great write up, mine's in to have the clutch looked at this week, I might ask them for a price on doing this too
RS4 Cabriolet - Phantom Black with Exclusive interior
Brooner
Post by Brooner » Tue Mar 12, 2013 4:04 pm
Excellent write up got be a sticky
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Teutonic Tuner
Post by Teutonic Tuner » Tue Mar 12, 2013 7:51 pm
Brooner wrote:Excellent write up got be a sticky
...it's already stuck! :thumbs:
Thanks for the comments.
alex020869
Post by alex020869 » Tue Mar 12, 2013 8:47 pm
Just came across this.
Brilliant tutorial. Well done.
Alex
RS4 B7 Mugello Blue Saloon
RS4pete
Post by RS4pete » Wed Mar 13, 2013 2:27 pm
Agreed! Great write up, changed mine and the positive difference is very noticeable.
Interestingly filling the rear diff to the fill hole took 1.1 litres yet I'd only removed 0.9 litres. So I removed .2 of a litre. Really just a FYI to recored how much you take out and how much you put in!
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit :)
